GG6 and 6.5 CCS Pads
lonye
Hi everyone.
My GG6 is on my way Home and my first detailing time is almost here (on my own car). I Already have Some 6.5' CSS Pads, but I've been reading and find out than many of you recommend 5.5 pad.
Does de GG has de power to spin de 6.5 pads with some level correction? or Is it a MUST to buy de 5.5 pads?
I'll be using Menzerna SIP/4500, M105/205 or Car Pro Fixer (that's the polish I'have. SOme of then where a gift so that's why I have several of them).
Thanks for your help!
My 7424XP needs the smaller pads but the GG6 has more power and has no problems spinning the larger pads. Since you already have the larger pads give them a try before you buy more pads.
I have the GG6 and have used the 6" pads. It can handle them with no problem.
Ok, so I'll give a try to my 6.5 pads.
Any thoughts about the polish I have? (Menz SIP, SF4500 - M105/M205 - Carpro Fixer)?
The car is a Ford Fiesta.
Thanks for Help and Advices!
The M105/205 combo can cover about 90% of any correction you have to handle.
That's excellent news! Should I use them with foam or MF pads?
I also hear that M105 has much cut power. If a paint is lightly swirl, should I tried first with Menzerna SIP?
Try SIP first.
Thanks! That's what I' do!
As soon as possible I'll post some pics!
