Glazes that work with WGDGS?
purplenurple
I am looking for a glaze, preferably OTC, that works with the WGDGS. The WG GLaze isnt quite doing it for me, and seems like a finishing polish type of product. I guess OTC glazes would be 3M hand glaze, and the Meg's glazes.
Also, would a glaze be effective at hiding swirls if it is applies on all ready sealed paint, or does it need to be directly applied to the paint?
Also, can I put a glaze over a sealant, and then sealant over the glaze again, for a deeper shine?
Thanks.
Probably nothing. If you have to glaze then seal you will need Wolfgangs glaze. Their glaze/sealant are designed to work together.
Menzerna's glaze and CG's WMF and Creme Glaze, and Danase's Wet Glaze all work with sealants.
CG? Do those work with WG sealant, and are they sold at Autogeek?
THe WG glaze didnt really add anything to the paint IMO
No wetness, no depth, little shine....
If not a glaze then, what can I use to hide the minor swirls that that car came with? Zymol cleaner wax thats sold OTC?
Also, whats a nice OTC wax that I can top WG sealant with? Megs Yellow wax? I forgot to order maxwax when I ordered from AG
Megs #26 is a good OTC wax. I happen to have it on my car right now with Opti-Seal on top.
Alrighty then, Ill go pick some up at autozone, or might go out of my way to check out carquest. Isnt opti-seal a sealant?
Chemical Guys, and its not sold here, seperate company. I don't think the WG Glaze is really a glaze in terms of the wettness and depth other glazes have, seems more like a fine final polish.
Could you PM me a link, Surfer?
I just picked up some DG AquaWax and Megs #26. Is it better to use AW when wet, or dry, and with waffle weave or regular mf? Does AW have a cure time or can I slap some #26 on there right away?
AW is better dry, wait till next day for it to cure. Just a light spray per panel and then spread with microfiber, flip over, and buff. You oculd use #26, then top with AW as well.
Ok, I was just making sure, becuase the bottle says that you can spray it on a wet car and dry + spread the wax at the same time. I was thinking about just dragging my guzzler across the car to get most of the water, and then AW.
bambo2888 said:
i have always used wg glaze and love it.
Any tips on using it? Maybe I didnt apply it right, or something? Would it matter that I applied WGDGS over the glaze on the following day? (car was in garage the whole time)
