I made a typo during my previous post, I meant the 203 for Power Finish. Must have been thinking of other things at the timeI used these pads...CCS foam buffing pads,foam polishing pads,lake country foam pads,foam polisher pads,buffer pads,lake county pads,porter cable pads,pads for air sander
I didn't use 205...not sure where you got that from. I did a test spot with Griots garage machine polish 3. Then a test spot with Menz Power Finish.
Decided upon the Power Finish and did a total of 5 section passes. 2 passes with med-heavier pressure on speed 5 on my PC. Then 2 passes med-low pressure on speed 5. Then 1 pass just the weight of the machine at speed 4.
