Got rid of my Overpriced Karcher PW and bought a Cheap Ryobi & Upgraded it... way better setup!!
zmcgovern45
The Karcher X Series...
About 4 years ago I bought a Karcher X Series (K5.540) , 2000 PSI, 1.4 GPM unit (product link) to be used for car washing. This was my first electric pressure washer, and I figured I would buy the "top of the line" expensive model so I wouldn't have any regrets later. Well, I screwed up....
The Karcher unit was... fine. I mean it sprayed water at higher pressure, so I suppose it functioned, but after fighting with it for so long, that is about the only good thing I can say about it. The hose was a stiff, cheap product that would never lay flat. It always tried to retain the coiled up shape even when it was uncoiled. Thanks to Karcher's unique connections, the only option that I had found to replace the hose was with another Karcher hose... so I was stuck with it. The spray gun and wand were also cheap, flimsy products. The variable pressure wand is a nice idea, however I only utilized the widest fan setting, so the variable settings were not needed by any means. Again, thanks to the Karcher connections, I was also stuck with this gun. Due to these proprietary connections, I also had to purchase an adapter to allow me to use my foam cannons with this sprayer. The attachment on the PW body to hold the gun while it was being stored fell off regularly, as did the hook to hang the extension cord on. This was an issue from day one. Very cheaply made, poorly designed pieces. In the end, it was the power cord that gave up on me, and instead of spending $20 to fix it, I sold the entire unit for $30 on craigslist. I just wanted it gone. Time to start over.
My inspiration...
I had watched some videos by Matt on Obsessed Garage where he went over a lot of the research he had done on pressure washer fittings, wands, guns, hoses, etc. and I became intrigued. I knew my next setup needed to incorporate some higher end components (hose and gun, specifically) so I would not have the same complaints as I did with the Karcher unit. I have always been a fan of the MTM Foam Cannons, so I spent some time on their site and the OG site checking out fittings, hoses, and guns. I liked what I saw so I decided to get to work....
The Cheap Ryobi...
I went to my local home depot and picked up the cheapest pressure washer they had. A 1600 PSI, 1.2 GPM Ryobi unit (product link). This unit retails for $119, but I had a coupon and got it for $101 + tax. I knew I would not be using the included hose or gun, I just needed the unit itself. This little thing is a great, compact size. It is very lightweight and easy to move around, unlike the overweight karcher unit I had previously.
Upgrading the Ryobi...
The output of the Ryobi PW is an M22 male thread where the supplied Ryobi hose would typically connect. Since I would not be using this hose, I needed to convert the M22 thread to a 3/8" coupler as that is a common size found on most higher end hoses. From there I needed the use the appropriate fittings to connect the hose to the pressure washer, and the hose to my new MTM SG-28 Spray Gun. A 1/4" coupler was added to the output of the spray gun to allow for easy changes between spray nozzles and foam cannons. The following photo shows the full layout of parts. Click here to download the PDF with links to all parts and a 2nd option to upgrade your hose and gun.
Some of the parts once they arrived....
Just put the new setup to the test today, and I am very pleased!!!
(Used with MTM Hydro PF22 Foam Cannon and Optimum Car Wash. 40* Nozzle used for rinsing)
Initial Impressions of the New Setup...
Man is it nice to have a 50' hose! Man is it nice to have a hose that doesn't get twisted and tangled! Man is it nice to have a PW that doesn't fall over!
Alright, so I do not have a hose reel on this new unit. This means I have to connect and disconnect the high pressure hose each time I use it which adds a couple of minutes to my job, but I sort of prefer it this way. The PW unit remains very compact and lightweight without the hose reel. I simply roll up my hose and hang it on a hook inside my garage above the pressure washer, just like I do with my garden hose. My foam lance and spray gun have spots on my pegboard.
The SG-28 spray gun is very nice. While it is still a completely plastic body, the build quality is much better than the Karcher gun. It just feels sturdy. There isn't a bunch of play in the trigger.
The MTM nozzles with the appropriately selected orifice size are fantastic!! It feels like this 1600 PSI unit has a much stronger stream than the 2000 PSI karcher did. I think the Karcher spray wand was the limiting factor there.
The connectors and fittings are very solid. No leaks, and no issues connecting or disconnecting anything during setup, use, and tear down.
At the end of the day, I spent less money on this new setup than I did on the Karcher several years ago. I feel the Ryobi (or other similar inexpensive unit) with the upgraded components is absolutely the right way to go for consumer setups! So far I'm very happy with my switch.
I'm in the same boat with the Karcher and really getting sick of the hose and the constant falling over. Thanks for sharing your setup - something I'll have to look into once I'm ready to replace it.
Hey Zach! Good to see you posting here again. My first electric pressure washer and current is the greenworks from Lowes. I didn't like the hose and wand it came with as well and had to buy separate parts to make it work for me. I will look into the ryobi brand for my next one.
Those little Ryobi units are pretty decent for the price. I get about 4 months out of mine using them daily before they finally seize up. One of them actually caught on fire inside my van after cleaning a fleet of buses in 95f weather LOL. Upgrading the hose is probably the single best thing you can do for these units as it seems to allow more water flow and more pressure to the gun tip.
Nice Zach! I did a similar setup. Bought a Greenworks from Lowes a couple years back and upgraded the hose to a very flexible 50' and got the pistol grip wand. Quick connects on everything and it's also super quiet which is great.
On a side note, the clear 36 ounce bottles with the dilution ratio on them are great for the foam cannon. Can set on the ground without tipping over.
I have the same Pressure Washer. It has been great. Amazon has a cheap reel that will fit on top of it without falling over. I added the reel to mine with 50 ft of hose and small gun. Very much like your set up :)
if my electric greenworks pressure washer stopped working i wouldn't hesitate to buy another or the ryobi. sometimes more expensive doesn't always mean better...
Your PW isn't pushing nearly enough PSI for the 3/8" hose. I think you're leaving performance on the table. Anyhow, if you're happy!
On edit: I decided to google my thoughts and came up with this....
https://www.autogeekonline.net/foru...oss-pressure-my-new-pressure-washer-hose.html
I use a Simoniz unit. I am mostly happy with it but like you I hate the cheap 10 foot hose that comes with it. It always wants to coil up and it's barelly long enough to go to the other end of the car. If it was 5 or 10 feet longer it would be perfect.
So, can you tell me how and where to shop for a replacement hose? I was under the impression you were stuck with the company you chose for your power washer, they all seems to have their own connectors and all. In my case, both my power washers have a hose to screws in the unit. I believe both are from the same company despite the fact they have different brands on them. I never checked if the hose were compatible with one an other but I believe they are. So with all that said, what are the steps you went through to find adapters and replacement hoses and guns?
And where did you purchase yours? I would most likelly try to do it locally but just in case ;)
The Ryobis use a pretty standard connection for hoses My hose fits on my small ryobi and large subaru gas pressure washer. M22. There a lot of choices for M22 hoses. I am not sure what size your simoniz uses.
Good thread. I was curious about the cheaper electric washers. I started a thread on another forum (Not AG) and was essentially told that gas was the ONLY way to go because the electrics were garbage.
Thinking I might try a greenworks or similar model. Lowes, Harbor Freight, Home Depot, etc. all seems to have their own name but they all have really similar specs.
-Emt1581
I am pretty sure the Harbor Models and a few more have the hose and guns that only work with their system. I highly recommend one that easily upgrades to a better hose and gun :). The stock hoses on a lot of the cheaper PW are not very user friendly this is 50 ft of ryobi hose and 50 ft of flexzilla hose side by side
-Emt1581
usually any gas pressure washer that's under $500 is not going to last a long time because the pumps will go out (good advice i was told) and aren't meant to be used all the time. they are also loud (neighbors aren't going to fall in love with it) and obviously need gas which adds to the expense. i've had my greenworks 1700psi electric pressure washer for over 3+ years and it's been good to me and i bought it form CL's for around $100 (got it for about half off retail) and it was nearly new...
I have the karcher k5 and it works great for me. The hose is long enough to go around the whole car and the units never fallen over. It has great power too. Its 100x better then the harbor freight unit i had. The foam i get with my hp gun is also perfect and the hose doesn't coil up. i dont know why you need a 50 foot hose unless you are washing a school bus? I have a small suv and the karcher hose goes around the whole car without moving the machine.
The only thing I don't like about the unit is the cheap plastic quick connect. Maybe you don't have enough water pressure at your house to take advantage of the power of the unit and the higher gpm?
That new setup he's using is not better then my k5 x series. The unit he originally had and got rid of. I'll have to disagree with his opinion here. The K5 is 2000 psi and has a 1.4 gpm flow. The unit he bought is 1500 psi and has a 1.2 gpm flow. Numbers don't lie.
I believe he thinks its better. Maybe he doesn'tt have enough water pressure at his house to fully take advantage of the more powerful unit? The k5 at my house is just about as powerful as a coin op
that's all that matters to the person who is buying and using it. btw, the statement can apply to many different things. not a fan of the fittings on the karcher so i wouldn't purchase another...
I think using a gas pressure washer to wash a car is going overboard. Unless you are washing cars all day long everyday for a business. the average guy washing 1 or 2 cars a week doesn't need a gas unit. Unless you want to use it to pressure wash vinyl siding or something
i def am not a fan of the karcher, cheap piece of crap, plastic quick connect fitting they give you for the water hose.
There is no difference you can feel between 1500 and 2000 psi. As for water pressure, try this: Hook up everything on your pressure washer but don't turn the power on. Then remove the pressure nozzle and squeeze the trigger to let water flow out of the wand. You will see that there is very little water coming out. Think about it. When the power is on, the unit will use about 1.4 gallon per minute, that is not much water at all and doesn't require much pressure. In fact most unit run perfectly well with a water tank that is elevated and don"t need a pump to feed the water into the pressure washer.
Disagree. I use my PW once a week. I had an electric PW before and they rinse tooooooo slow. Plus, foam is weak from an electric PW. Even if I didn't use a foam cannon, I'd still prefer a gas washer for sure!
