Got rid of my Overpriced Karcher PW and bought a Cheap Ryobi & Upgraded it... way better setup!!
Re: Got rid of my Overpriced Karcher PW and bought a Cheap Ryobi & Upgraded it... way better setup!!
Price still shows 79.99. It might be a permanent reduction, as it doesnt show as a sale price anymore.[/QUO
Just checked, at this moment, still at $79 on the website. Ordered mine yesterday with free shipping to my door. I went with the Ryobi simply because of the excellent info provided by Zach for various upgrades - and the fact Zach has had his for a while and it seems to still be kicking.
I also just picked up the Ryobi unit for $79.99. I was going to get a gas unit but probably overkill for my needs. I’ll post impressions after I use it.
Im going to attempt to put a polyurethane or rubber hose on my k5 with clamps or something.
So I opened mine up today. Had a real bad experience. Low pressure and thing smelled like it was burning after 3 minof use. Definitely returning tomorrow and will spend a little more for something better. I tried using w my mosmatic gun but pressure was way low. Never got to try my mtm foam canon. The hose they include in box is not only short but kinks easily. I wanted to try factory hose before upgrading. I know now for a fact that I will need to upgrade the hose.
Ended up washing my car w the foam gun and had some fun anyway.
I picked up a recon ryobi for $60 last fall and after changing the hose and gun I really love this thing. I also have a gas unit but I will use that on the house and deck and keep the electric for the car. With this setup I have no problem making foam with the gun and I love the size of the unit for storage. I use a zeroG hose that will fit in a 5 gal bucket and leave the washer on top of the bucket.
If anyone is on the fence about ordering the parts that Zach recommended, MTM hydro parts has a 20% off coupon running now: BJPB
It'll help with the shipping basically.
That's a bummer man!
The problem is the Karcher pressure washer. They use their own fittings so no other hoses fit the unit.
You can check with Karcher to know what fitting they use. It's very likelly they use the M22 15mm ones. Looks like most electric pressure washers use that size. There are adaptors available to convert M22 15mm to M22 14mm which is more standard.
You could probably have adaptors to other standards as well, you just need to know what your unit has and what the hose or gun you want to use has.
Although using a larger diameter hose will result in pressure loss, so that is not a good idea.
Same problem with the SunJoe PW--they use a M22-15mm connection and the standard is M22-14. But an inexpensive conversion fitting is available on eBay but I can't find the link just now.
the M22/15 is the European standard. Yea, eBay or MTM or some Googling will find the parts you need to adapt. I have the SJ3001 also and fully converted it over
to American standard & quick release too.
Calnedyr - just reading your questions about the Simoniz brand pressure washer. I also own a Simoniz electric and a Yamaha gas power. I bought a new 50' single wire hose which are more flexible then the double wire as well as a new gun and wand. For the simoniz I had to buy a M22-3/8" for the pressure hose outlet on the machine and a M22-1/4" quick connect so I can use their foam cannon with my new gun. Hope this helps. If you want pictures let me know.
Just received my new gun today and finaly was able to try the new setup.
Simoniz 1700 PSI pressure washer
23 foot pressure hose from the original setup
25 foot pressure hose extension using the M22 15mm to M22 14mm adaptor
Sub-machinegun style trigger sprayer with M22 14mm connector and 1/4" quick connect for nozzles and foam cannon
So first, plenty of lenght, could go around the car with no issue at all.
The new sprayer gun is much easier to use than a 3 foot lance. You do get some splashback from being closer but that's all right ;)
Pressure felt stronger, I know this is an illusion but it's still good ;)
Machine does take about an extra second to shut down when you release the trigger because it has twice as much hose to repressurize. But that's not an issue at all for me.
Very happy with the upgrade. Just love it ;)
Alright. I tried a second time. Replaced w a Ryobi 1.2 gpm 1700 psi unit. It’s a little bigger than the one I had but at least it hasn’t blown up on me yet.
First off,I love my mosmatic gun w swivel. Looks good,doesn’t get tangled, and looks like a quality piece.
Second, the pressure washer and factory gun/wand work well for pressure washing my patio :).
Third, foamability is not living up to my expectations. I have a brand new mtm foam canon and have tried various settings. I also use Chemical Guys Honey Dew soap. Have super weak suds at best. Pretty much equivalent to my foam gun that works w a garden hose.
I’ll keep messing around w this setup to see if I can improve my foam. Otherwise I wasted good money on my mosmatic and mtm foam cannon cause there was no need for them if I don’t get the foam.
You are going to need to switch the orifice to 1.1mm in the foamcannon from the original orifice 1.25mm. Then you get a thicker foam with your PW.
+1 I was just about to write the same thing. the MTM comes w/ an orifice designed for higher pressure gas powered washers.
Unfortunately, the only place to get them is MTM and the shipping is 3x the cost of the orifice. :(
That's not entirely true. They are available elsewhere if you know where to look.
