got the small ones but the BIG swirls are still there...
2000 mustang painted complete in 2005 at a body shop 4 coats of clear.
I scanned right past the paint job part... :dunno: sorry about that... multi-tasking...
3-6 passes on 5-6 setting on the PC. moderate to no pressure and i can see it turning but i need to make a mark on it.
See below...
Did you say you were using little pressure?
chevchenko nailed it... at least a major factor and that's downward pressure, especially if the paint is hard.
Take a moment to read through the below, use it as a check list to see if there's anything else on the list you might be missing...
DA Polisher Trouble Shooting Guide
When you're first starting out machine polishing and learning to use a DA Polisher it's common to have questions about your results and your results are directly tied to your technique.
Here's a list of the most common problems,
1. Trying to work too large of an area at one time.
2. Moving the polisher too fast over the surface.
3. Using too low of speed setting for removing swirls.
4. Using too little downward pressure on the head of the polisher.
5. Using too much downward pressure on the head of the polisher so the pad quits rotating.
6. Not holding the polisher in a way to keep the pad flat while working your compound or polish.
7. Using too much product or using too little product.
8. Not cleaning the pad often enough.
Here's a list of the solutions in matching order,
Shrink the size of your work area down. You can't tackle to large of an area at one time. The average size work area should be around 20" by 20". Most generic recommendations say to work an area 2' by 2' but for the correction step, that's too large. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot. The harder the paint the smaller the area you want to work.
For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's easy and actually natural for most people new to machine polishing to move the polisher quickly over the paint but that's the wrong technique. One reason I think people move the polisher too quickly over the paint is because they hear the sound of the motor spinning fast and this has psychological effect which causes them to match their arm movement to the perceived fast speed of the polisher's motor.
Another reason people move the polisher too quickly over the paint is because they think like this,
"If I move the polisher quickly, I'll get done faster"
But it doesn't work that way. Anytime you're trying to remove swirls, scratches, water spots or oxidation using a DA Polisher you need to move the polisher s-l-o-w-l-y over the paint.
When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting but this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad oscillating and rotating over the paint as well as the combination of time, (slow arm speed), together with the abrasives, the pad aggressiveness, and the downward pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches.
Removing below surface defects is a leveling process where you need the abrasives to take little bites out of the paint and to get the abrasives to take these little bites with a tool that uses a Free Floating Spindle Bearing Assembly you need all of the above factors working for you including a high speed setting.
For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much downward pressure to the polisher and the result of too little pressure is no paint is removed thus no swirls are removed.
If you push too hard you will slow down the rotating movement of the pad and the abrasives won't be effectively worked against the paint. You need to apply firm pressure to engage the abrasives against the paint but no so much that the pad is barely rotating. This is where it's a good idea to use a permanent black marker to make a mark on the back of your backing plate so your eyes can easily see if the pad is rotating or not and this will help you to adjust your downward pressure accordingly.
Correct technique means finding a balance of applying enough downward pressure to remove defects but not too much downward pressure as to stop the rotating movement of the pad.
This balance is affected by a lot of factors like the lubricity of the product you're using, some compounds and polishes provide more lubrication than others and this makes it easier to maintain pad rotation under pressure.
Another factor that can affect pad rotation are raised body lines, edges and curved surfaces as anytime you have uneven pressure on just a portion of the face of the pad it can slow or stop pad rotation. This is where experience comes into play and experience comes from time spent behind the polisher.
Applying pressure in such a way as to put too much pressure to one edge of the pad will cause it to stop rotating and thus decrease abrading ability.
Too much product hyper-lubricates the surface and the result is that abrasives won't effectively bite into the paint but instead will tend to skim over the surface. Overusing product will also accelerate pad saturation as well increase the potential for slinging splatter onto adjacent panels.
Too little product will means too little lubrication and this can interfere with pad rotation.
Again there needs to be a balance between too much product and too little product and finding this balance comes from reading articles like this one, watching videos an most important, going out into the garage and putting in time behind the polisher and as you're buffing with specific product and pad combinations, pay attention to pad rotation.
Most people simply don't clean their pad often enough to maximize the effectiveness of their DA Polisher. Anytime you're abrading the paint you have two things building up on the face of your buffing pad,
  • Removed paint
  • Spent product
As these to things build up on the face of the pad they become gummy and this has a negative affect on pad rotating plus makes wiping the leftover residue on the paint more difficult. To maintain good pad rotation you want to clean your pad often and always wipe-off any leftover product residue off the paint after working a section. Never add fresh product to your pad and work a section that still has leftover product residue on it.
Pad Cleaning Articles
Why it's important to clean your pads often...
How to clean your foam pad on the fly
:xyxthumbs:
since this is your first time detailing i would watch some more videos on how to compound/polish a car with a DA.
do a test spot!!!! don't do the whole car, cause you will be upset with the results. Test 4-6 slow passes in a 12"12" area with different product/pads.
I tend to use 4-6 passes in a 16x16" area. I have to remind myself to slow down. I use typical i find most daily drivers need megs ultimate compound with orange pad. Sometimes i bring out m105 with orange/cyan or surbuff pads if i want more cut. Always follow compound with a polish i like megs m205 with white lc or tangerine hydro pad.
Don't expect perfect reuslts the first time. it takes a good 10-15 hours to really get the hang of a DA. after the 4-5 car you do you will feel like a pro. just remember slow passes in small areas.
well it nt my first time detailing as i used to have a small business doing it, we just didnt do paint correction. this is just my first time using the PC, ive buffed a $250,000 show car with the dewalt, i just dont like the heat from it...im it in 6 hours already and another ful day tomorrrow to get the rest of the car done, sealed, glazed and waxed
imo, if you are using blacklight, then you don't need jetseal...
This is a pretty old article I wrote on MOL, it dates back to 2004, but it shows and talks about downward pressure with pictures...
How to use the G-100 to remove swirls
See below...
  • Removed paint
  • Spent product
:xyxthumbs:
you are the man!!! i had to stop and actually go buy another pad cause the only way i knew to safely clean these pads were washing in a bucket....at the body shop we just used a screw driver lol
I forgot to mention slow passes! Mike really got the major parts down in his bullet points. Slow, 15-20 pounds of pressure, which is almost enough to stop the machine, even pressure so the machine does not lean or tilt, and then not too much product after you have primed it. Note that as you move through the process from compound to med. polish to the finer polishes, glazes, and then the LSP (sealer or wax), you lighten up on all that I just said accordingly. In other words, you now move the machine a bit faster, use less pressure, and use a bit more material, and this is accelerates as you move up through the process. By the time you get to the sealer you are using just enough pressure to balance the machine well, and you are moving faster and thinking about working the material into the paint. Another way of putting it is your mentality changes: you go from thinking about cutting, to filling and working the material into the paint. Hope it helps.
