Definitely..more power and life time warranty. Put a 3"backing plate on the PC for tight areas, headlights, carpet cleaning etc.I currently have a PC 7424 (not the XP) and was considering the purchase of a G9. Would this be an upgrade from the PC 7424. I am only using it on my wifes and my own car.
Does the lifetime warranty only apply if you buy from Griots?
Not unless it's from a black market source.
Your covered Bro!I would probably buy from Autogeek along with some other items.
I thought if it wasn't direct, you'd be dealing with the place you bought it from if you had a issue. Direct, I believe they also have a 180 day return policy.Does the lifetime warranty only apply if you buy from Griots?
(Unless you were to be working on the sides of cargo vans all day long).
Autogeek regularly does 15% sitewide though.
I referring to a sale like this, which was in May. They're currently doing a sale on $100 gift certificates, which could be used.The sales I've seen exclude polishers, but you do get rewards for you purchase.
Grab the Griot's 5" backing plate and 5 1/2" pads in your order.
Yes, the G9 has enough a$$ to churn the 6". But I have found it very unpleasant to use. (Unless you were to be working on the sides of cargo vans all day long).
I think I am going to order the 5.5 inch flat pad kit.
After thinking about it I was wondering if I would be better off buying the G9 and and the CCS Lake Country 6 pack of foam pads and picking what pads I want. My paint on my Jeep is in pretty good condition so it needs very little correction.
Absolutely. But, I think you would be better off getting the LC Flat pads rather than the CCS.
Any suggestions as to which pads to order?
