PA DETAILER
- Mar 5, 2011
- 6,017
- 251
Griots joins the Si02 wagon.
Ceramic 3-in-1 Wax is formulated with liquid polymers and SiO2-infused chemistry that forms a chemical bond with your paint to impart a layer of protection that is more robust than conventional waxes and sealants. Designed as a supplement to a professionally installed high-solids ceramic coating or to be used in place of conventional waxes or sealants. Ceramic 3-in-1 Wax guards against surface oxidation, harmful UV rays, stains, etching from acid rain, and other environmental/chemical sources. It also makes maintaining your paint much easier via the formula's self-cleaning properties that reduce dust and dirt buildup. The best performing, easiest-to-use sprayable ceramic on the market. Take advantage of Ceramic 3-in-1's leading-edge technology and take your paint protection to the next level.
