Griots, Flex, Rupes DA clone
The MaxShine isn't so much a copy. Its their own version of a high throw polisher. The reason people assume the AnsiAuto is a copy is because it looks darn similar to the Rupes. The internals have some resemblances as well.
FYI Maxshine makes GG polishers. Connect the dots. You can not purchase individual MaxShine polishers. The minumum order is 500 pieces.
It sure does have a "Griots look" to it!!!
[ame=http://www.youtube.com/watch?v=6MLd370O0Uc]Ansi Auto Rupes 21 Clone - YouTube[/video]
Just a quick video with some pictures and a small video of it running at speed 1, 3 and 6.
My stuff comes on the 6th with the 5" backing plate and the 7" & 6" foam pads, I also have 5.5" nano scrub and 5.5" microfiber pads.
Better pictures here...
Better pictures here - imgur
Very interesting, hope to see more people playing with these.
Does it have the same slow start feature that Rupes has? Hard to tell in that video.
When you're on speed 1, it seems to go higher than 1 and then come down and settle on a low speed.
When you're on speeds 3-6 it does appear to ramp up from a lower speed and then up.
If you're holding the trigger down and let go for a second or two and hold it down again, it slowly ramps back up to speed from the speed it was. Its not just instant power, there is a noticeable lag. However if you let go and let it stop, it does the ramping according to the speed you're on.
I dont have a rupes, so I dont know if this is the same or not. I have not had the chance to use it on paint yet however as my xmas order with rupes backing plate and pads to fit the machine arrives on the 6th.
Look what I saw on one of chemical guys youtube videos promoting their smart detail university....
Don't they sell Rupes? Shame on them. Is that going to be the new Vintage Series DA or something? People should boycott any detailing supply place that sells those things.
Here's an interesting one:
Looks like someone got a GG6, a 3401, & a Meg's DA and threw them all in a blender.
Hey swanic, funny you mentioned this! I am in Australia and just got this Rockwell DA polisher. I was browsing at local supercheap auto few weeks ago and saw this DA on sale for AU$80 which was pretty cheap! So what the heck I just bought it thinking I can always return it later if I don't like it or can't use smaller backing plate! :p
To my surprise this DA is surprisingly smooth and feels solidly built for the price! It has 8mm orbit, soft start, bonus 7" pad, but it's loud and only 600W.
I already have Bosch GEX150 Turbo which is forced rotation like Flex 3401 but only accepts 6" backing plate. This Rockwell DA accepts standard backing plate so I can use smaller pads next time!! ;)
Just for price comparison, Megs G220v2 retails for AU$300 (now discontinued). Flex 3401 & Rupes 21 are both around AU$600. Festool Rotex 150 around AU$900. This Rockwell DA retails just AU$100 ($80 when I bought it on sale) and includes bonus pad!
I say good. These aren't precision machines and they shouldn't cost much money. Guys who do this for a living need at least a PC. The rest of us would be well served by these machines.
I ran into a few issues with mine. One being that the rubber vent shroud between the backing plate and the head of the polisher was getting caught and eventually melted the back of my backing plate a bit.
I tried cutting it back to the back of the vents but the thing is really loose and eventually works its way down back onto it. I wound up tossing that piece of trash and going with nothing between. Its worked out much better.
The second issue that I ran into is when I was using the rupes 5" backing plate I'm fairly certain the rubber shroud was catching and it backed out the center counterweight screw and the head dug into plastic and created a groove. I went ahead and screwed it down tight but mean to put some blue locktite on them. I recommend the same for others who have it.
Other than that, after taking the rubber shroud off and tightening the counterweight screws this thing has a ton of correction power and I'm loving it with the rupes 6" and 7" OD pads. I also have been using it with my nanoskin clay alternative pad and waxing my vehicle. Nice thin coats. Pairs nicely with my old style white chemical guys microfiber pads as well.
If this thing breaks I might just go ahead and bite the bullet and get a Rupes or another clone if someone distributes it with a warranty.
I noticed this problem before I even started using it. It took me 5 minutes of breaking it down to realize that not only does the shroud contact the backing plate but so does the counter weight. There needs to be a spacer to space out the backing plate and the machine.
Sounds like quality engineering. The machine comes new out of the box that way? Oofa.
