WRAPT C5Z06
- Nov 12, 2009
- 12,615
From the videos I've seen, the polisher seems to be MUCH better balanced with their 6" backing plate. The 5' backing plate looks to really wobble.
Interesting you should mention that. Just got my G9 last weekend. I used Uro-fiber pads in both 5" and 6". I used the 6" first, then 5" and it sure seemed like the 6" did rotate better when up against a contoured area, but I decided it was just faulty perception due to not having enough run time with it. I thought it was my imagination so I'm glad to see you had the same results and I'm not losing my mind!Interesting. I can’t say from my time using my G9 (complete 2 step on a Q5) that I thought the vibration was excessive/notably higher with the 5” plate on it.
Throughout the course of the detail, I changed pads/formats quite a bit (all with Griot’s pads). I used 5.5” BOSS pads, “regular” pads, and BOSS Microfiber (red foam version) pads. I also used 6.5” regular and BOSS pads.
One observation that I did have was that there was seemingly no drawback to using the 6.5” thick pads. The machine never broke a sweat maintaining pad rotation (usually around speed 4.5), and actually maintained rotation better in the really contoured area where the side of the hood meets the front fenders than with the 5.5” BOSS pads. (I meant to take a picture - if I held my small handheld Milwaukee Rover stick light about 8 inches away, the contours made the light reflection S-shaped. Now I’ve gotta get a picture of it...)
Balanced is a great word for the machine though - with any pad setup the weight distribution of the machine is such that it’s super easy to find a comfortable hold on it while maintaining pressure against the paint.
I’ll be honest and say that at first it wasn’t as noticeable a difference in vibration level (IE: Less) from the GG6, but then I realized I was gripping the machine much tighter than I needed to while getting accustomed to it. Once I softened up it did strike me as smoother. You can also run it at a lower speed while still maintaining rotation which is nice.
Disclaimer I feel I always need to throw in - I’m no pro, so I don’t have countless hours with various tools; these are just my thoughts from my time with the GG6 and G9. I’ll be pulling it off the shelf again soon to start correcting my DD, which I’m really looking forward to.
... . I thought it was my imagination so I'm glad to see you had the same results and I'm not losing my mind!
I’m curious as to why griots would promote (sell) the new polisher as a 6” when we’ve been told for years that a 5” backing plate with 5.5” pads is better. Why does Griots do this when the first thing everyone does is buy a smaller backing plate and smaller pads?
I’m not criticizing at all. Genuinely curious.
I have 6 and 5 inch plates, I haven't noticed any wobble at all!From the videos I've seen, the polisher seems to be MUCH better balanced with their 6" backing plate. The 5' backing plate looks to really wobble.
Not sure how could could say this? Based on throw alone, the 15mm will out cut the G9. It also look like the G9 stalls easily on curves. Take a look at auto detailing podcast review of the G9 on YouTube.I put it up against any 15 da out there!
Do you use a 5” or 6” plate?I mostly agree with this statement, I love my G9 the more I use it and it is proving to be a very capable and impressive machine, but I do not see how it could compare to a any 15 DA. However in my experience, I have not noticed any stalling on curves.
