Brownie
- Apr 3, 2014
- 66
Hey, when I came to Griot's Garage last year, I evaluated their entire buffing pad line and redesigned it from the ground up. The new pads are 3", 4", 5.5" and 6". We ensured there was a safe distance between backing plate and pad, by chamfering the edge. We no longer offer a 6" pad, as it is too close a proximity to the backing plate and could lead to paint damage. The new pads feature a thermal-set bond and will not delaminates. All the pads use reticulated foam , so they're made of the most durable foam available. This also aids in cooling. The shot of the pad with deteriorated foam is likely from applying too much pressure and not rotating pads. Some great comments mentioned above btw. I'd use a minimum of 2-3 pads for average vehicle. Frequently cleaning the pads is essential too, as they will absorb compound and polish increasing their weight by as much as 100%. This added weight will increase the wear on the bonding of the pad and deteriorate foam as wellCan you use the 6" Griots Foam Pads on a 6" Griots Buffer with a 6" backing plate or should you use 6.5" pads?
Ps Fast Correcting Cream wipes off nicely. It won't oil out and clot/dry on the surface. In product development, I believe to deliver optimal performance, a product should be specifically designed for the application method. But that's a whole other discussion.
