danieledwards12
- Jul 22, 2013
- 103
Ok I am ready to try paint corection. Well correction in the form of using an AIO. In the future I will be purchasing Hd Speed. But for now I want to use Griot's Garage because I can get it over the counter locally. I will also be using Griot's Garage pads becuase I can also get them locally. I will be using a Porter Cable with a 6in backing plate. Ok now for question overload!!
- Which Griot's Garage product is considered an AIO? Their names and discriptions confuse me a little.
- Which Griot's Garage pad should I use when doing a one step AIO?
- How many of said pad will I need to complete one vechicle?
- What Speed do I use on my Porter Cable?
- I will be working in 2x2 sections. Do I correct that section, let it cure, remove cured product then go to next section? Or do multiple sections before removing cured product?
- How long do I let each section cure before removing product?
- I will start off by applying 5-6 pea sized dots of product on my pad. Will I have to add more product in the process of that first 2x2 section? How do I know when I need too add more? Do I add more each section?
- How do I know when I need to start using a different pad?
