Currently have a G9 and was looking to get a G15. The issues with the G9 and a 5 inch backing plate is that with todays newer cars the G9 stalls a lot. So my question is,
Does the G15 with 5 inch backing plat stall on curves.
G15 will stall more than G9. The longer the stroke of the polisher, the easier it is to stall. Granted some overcome that with extra power but the G9 is plenty strong.
Improve your technique or buy a Flex for forced rotation, nothing stops that.
After using my G15 a couple times, I can't imagine how hard I'd have to bear down to stall it out. The motor is pretty stout and drives the backing plate and pads pretty hard. I works hard enough on it's own I've not encountered a situation where I've had to put enough pressure on it to come even close.
Right, but try lifting it and putting the pad at an angle, it will stall easily. That’s why I said if he was having issues it’s likely due to technique. If you keep the pad flat and put normal amount of downforce the machine will keep pad rotation almost all the time. It would have to be a very curvy panel to give you trouble.
So you haven't had your G14 stall?
Original boss machiene came out thr Maxshine factory one of the two major ones( other being AutoAnsi? AnsiAuto?)Paul - yes, could be as you described with the lower prices on TV's.
All - My question really wasn't aimed at the notion of product quality, although some replies seem to have assumed that. More specifically, I have made a personal decision I will no longer purchase anything made in China where other options exist. No one has to agree with me, and no one has to do as "I do".
It is my belief that we can/should make things here in America (including the downstream supply chain) and employ our own people; especially when the company is American-owned. Again no one has to agree; I speak for myself. Change takes time, and starts with one person and one action.
P.S. I am also in the pro audio industry and the sentiment there is even stronger. Pro audio engineers have put manufacturers on-notice, sending a loud and clear message to manufacturers. It is being referred to as the "Quit China" movement.
Be well,
ScottH
