rockford33
- Oct 12, 2010
- 162
So, I have a couple of questions regarding Griot's Garage Paint Prep. I researched some and saw that Mark (07-z-06) used it to strip some Dodo wax he had applied a couple of weeks prior. What wasn't mentioned was if the car was being polished and a new LSP applied, or if he just wanted to try out some other LSP, so stripped off the Dodo.
1. If you plan on polishing the car, do you really need to use the Paint Prep to strip off the old lsp? Won't the polish do that for you? Or will the Paint Prep make it a little easier to polishi since then you are really at the clearcoat without any lsp in the way?
2. About how much of the Paint Prep is required for a mid-size sedan (and does it depend on the lsp cuurently on the car, like Collinite 845)?
3. Will it also strip UTTG? I have that on my exterior trim currently. When I go to polish this fall, if I use the Paint Prep will it strip everything, including my UTTG?
Thanks,
Neil
Thanks,
Neil
