Griots garage reliability
techaview
Has the new GG6 3rd gen improved on reliability? Any existing owner can give some feedback, like how long u have used the new GG6 before it goes haywire? I am comparing it with PC7424XP...
Reason I am asking is because I am not located in US and although GG6 offer lifetime warranty, whenever there is a problem with GB, I will have to ship to and fro which will cost me around 50usd each trip... hence the ergonomic of ownership is not there....thanks
It's funny, now that you mention it, I haven't noticed a lot of "my polisher died" threads lately, and we were getting plenty of GG, G110, and even some (mechanical failure) PCXP threads like that. Unless I have just been tuning them out.
Unless it's just that Mark/5.0 has been buying cars instead of polishers lately...wait, he's always buying cars...
Like Setec said, there has been a significant lack of mechanical issues with buffers recently compared to say a year ago, I'd attribute that to a couple of things, 1. The Rupes 2. The Flex and 3. The GG6" Gen 3. Since the Gen 3 has released, I can only recall 1 thread where the machine failed, and was promptly replaced, and many, many other threads where the 2nd gen failed, and was promptly replaced with the 3rd gen.
Even at $50 for shipping, that's only $50 for another machine compared to what the cost would be for a new one that doesn't offer the same warranty. I say go for it.
I linked "mechanical failures" to the PC XP because a couple of members broke the shaft, I can't remember any electrical problems with the PC. The G110, and the old, original Ultimate Detailing Machine had ongoing switch/cord problems that never seemed to get resolved until after the G110 was not available for a long time. (perhaps indicating a change in the mfr.)
I'm trying to remember if the GG6 problems were the same or if they were just complaints about some of them having more grunt than others.
That is why I posted this questions. Seem like all the issues pertaining to GG6 are from gen 2, unless the take up rate for GG6 is not high.
Anyway if I can recall shipping will cost me 100usd to and fro. In a way, u r right. In a scenario if it really spoilt 3 years later, PC warranty will be over and I can use the 100usd to get another working set as compared from buying a brand new one again. Who know I may be getting GEN4 instead.... :)
If it helps, I called GG when the 3rd gen came out to specifically ask how it was different then the 2nd gen one I own. What I found out was the guts are the same but they moved the on/off switch and speed control to the top, added more venting to help the machine run cooler, and drilled holes through backing plate to help disperse the heat generated between pad/backing plate while in operation. So it should be just as reliable if not more then Gen 2 due to the increased cooling abilities. I also have the 3' GG DA and like it for small jobs.
Dude thanks for the info. At least I know they have tweak the design over gen2 to overcome some of the heat issue...
Btw from the section from your quote, does that means it is not recommended to switch to after market back plate for eg, LC 5" back plate? Thanks
You're very welcome! You'll be fine switching to a LC 5' plate, as long as 1) you've got enough pads to work with and 2) are swapping them out/ cleaning them off after every so many panels.
First time I used my GG I was very surprised at the amount of heat generated between the pad's velcro backing and the DA's backing plate. I was even more surprised when my over saturated pad exploded while finishing off my front bumper!! A rookie mistake at the end of a long day :doh: I now have an ample # of pads...
As far as the ideal # of pads? There are tons of threads on this very topic, ways to clean them on the fly (Thank you, Mr. Phillips) and get the most bang for your £.
Good luck!
the issues that you mention in all DA, are for hard use? I mean 5 days a week.
Yes I saw the clip on cleaning pad on the fly by mr Philip.... Simple and yet effective. I am planning to get at least 2 x orange/2 x while and 2 x black/gray pads for a start. Adding on my arsenal at a later stage....
If you're going to buy two, I'd suggest instead getting a GG6 and a GG3. Might as well have a second polisher that expands your capabilities rather than collect dust waiting for a failure that may never occur. Besides, they match now :)
I have both and haven't had any issues with either one.
...or get two GG v3 and put a 3" smaller backing plate on one which will increase it's polishing performance and allow you to expand your polishing into smaller areas on the car without loosing down time of changing backing plates and pads.
With the added bonus if one does go down you have an exact backup.
Not a bad idea at all, however a 3" pad on the GG6v3 is, IMO, concerning as the shroud (at least on the 3rd gen) is around 4" in diameter. It's a larger shroud than on the PC 7424XP.
All I would say is to be aware of this.
If the machine is going to get in the way of a small pad, it kinda defeats the purpose of using a small pad to begin with...
Thanks dude. right now just starting out on my detailing journey. probably will stick with one that is versatile and suit my need. will consider getting another once i have more experience on using if.
btw any thoughts on the diff of using 6.5 and 5.5 pad on GG? They are really not much of size diff except on tackling curve spot or hard to reach spot...
Since it comes with a 6" BP, you could go that route. Personally, I prefer 5.5" pads since my car doesn't have a lot of flat areas. Either is fine though.
I got the 5" backing plate and 5.5" pads as I see it being easier to work with. I would share what others did that is getting more pads specially if you're buying abroad. I bought 12 pads (5 each of LC flat pad orange and white) then 2 of the black.
I have had no issues with my third generation 3" GG polisher. Using the red pad, it applies waxes and sealants better than anything I've ever used. Nice thin and even layers. Well worth the money.
