theory816
Member
- Aug 25, 2015
- 57
Hi all. Just got me a grit guard and this is the biggest problem with it:
The Guard sits too low.
This is bad for a couple of reasons:
1.Bad for sponge users. If you don't know, sponges are the best media for washing your vehicle. Not mitts not mf towels or anything of the like. So if im using a sponge and I need to squeeze out the dirt, Im suppose to push my sponge all the way to the bottom and push it against the guard. However, in doing this, youll splosh up the dirt and oil back onto the sponge . If the guard sat closer to the top, you wouldn't have this problem as there's no way for any water currents to be strong enough to disturb the dirt and oil at the bottom.
2. Bad for people who use gloves. I use rubber gloves. I just don't like any chemicals on my hands no matter how safe they are. If im having to put my hands all the way to the bottom in order to clean my sponge, water enters my gloves defeating its purpose.
Solution?
get a pvc pipe, cut 2 cross sections on one end so that the guard can sit higher than halfway in the bucket.
Solution?
