Gtechniq exo white spot. Help !
turbocat1100
Alright folks not sure this is in right part of forum,but question. I recently did a 94 viper full correction. After all correction work done, followed it with a 70% ipa wipe down. Then went over with Gtech Exo, View attachment 50785View attachment 50786Car looked great when took back to owner. Week later I get a call back starting their is white looking spots under coating. Any ideas thanks for the help.
I an't zoom, so I can't see it. Hope some one can.
Did the coating get wet the first 12 hours father install?
I'm guessing not many people are responding b/c no one can see what you're talking about in a .17 megapixel image.
We do need to know if it got wet, like vobro asked. We also need to know if this was done in direct sunlight, or how warm the body panel was when the coating was installed. Could be defects that you couldn't see during the correction phase, but appeared once the paint cooled. See Kevin Brown's latest interview on the Ammo podcast for more on that.
Will try to post better pictures tonight. The car did not get wet for over 24 hours I no that cause it has sat inside my shop before delivery. Correction and coating was also done inside shop as well nothing was exposed to outdoors and lighting is 100% in shop with different variations of 5000k bulbs and led lamps. Not sure on panel temp as I did not take a reading but was not exposed to direct heat to cause any type of warm spike.
I can't see anything. try and get a better, larger image if you can.
