brondondolon
- Nov 12, 2013
- 1,254
spiderweb swirls
I wanted to do this today, but my friend wanted to read it so I don't have it right now...@!$)Nope...
Need to read my book Antti!
:laughing:
Swirls, but don't have the book for deffinition
Sent from my XT1030 using AG Online
Tracers?
Rotary Buffer Swirls
Also called: Holograms or Buffer Trails
Rotary Buffer Swirls, also called Holograms or Buffer Trails are circular scratches inflicted into paint by a rotary buffer and usually by the individual fibers that make up a wool cutting or polishing pad. The abrasives used in most compounds and polishes can also inflict swirls into a car's finish, thus anytime you're using a wool buffing pad and a compound or polish you now have two things potentially inflicting swirls into the paint.
Foam pads can also inflict rotary buffer swirls into paint depending upon the aggressiveness of the foam formula and the product used.
It is the direct drive rotating action of a rotary buffer that instills the circular pattern of scratches into paint usually in some type of zig-zag pattern that mimics the pattern in which the buffer was moved over the paint by the technician.
A rotary buffer is not evil because it and the buffing pads and compounds used with it impart swirls into paint, it's just a part of the cause and effect from using a direct drive tool that rotates a buffing pad in a single rotating direction.
Rotary Buffer Swirls usually show up when a car is exposed to bright light like the sun when its high overhead in the sky.
It's possible to use a rotary buffer and not instill rotary buffer swirl if the operator has a high skill level and uses quality pads and products. If rotary buffer swirls are instilled into paint, a true professional will do a follow-up process to remove them using less aggressive pads and products and sometimes switch to a different type of tool with a different mechanical polishing action.
The primary visual difference between Rotary Buffer Swirls and Cobweb Swirls is the rotary buffer imparts this identifiable pattern while Cobweb Swirls do not.
Halogram
Ding Ding Ding Ding
We have a winner....
I asked for one word and that would be
Holograms
But we're easy around here.
To make sure everyone understands it's the lines and not the swirls I'm referring to, I've drawn an outline around the holograms using the same picture as seen above.
See them now?
