Daviddear30
- May 7, 2011
- 1,433
- 237
I just picked up on today. $65 for polisher and 3 pads
Someone can correct me if I am wrong but if the backing plate fits a PC, it will fit the HF DA.
This is what I use on my HF DA
lake country 5 inch backing plate, 5 inch backin plate, 5 inch hook and loop backing plate
Reading all this has sold me. I will be buying this. Will that cupon in the middle of this thread work still? It is online for 60 bucks. There are 3 stores I can go to, so I guess calling them to see if in stock is a good idea? Or do I just need to google HF great deal cupon or something? I was wondering about the HF pads, I had planed on a 5 in flex pad from CG's and the Hex pad sample kit Or maybe a LC 6 pack. not sure what chemical system to go with. its a bit overwhelming for a noob. Right now Im on the fence over Poor Boys, Megs, 3M, or Mothers. Feed back please
This is a heck of a start up since ill basically be a weekend warrior. guess Ill get a rotary too. I plan on doing some painting and since ill be wet sanding, will need it. Or will I? wont a yellow pad and some aggressive compound get rid of wet sand marks if they are around a 2500 or 3000 grit wet sand? ok you can tell im just getting this since all my questions run together. thanks in advance.
The LC pads are a better deal, but I slightly prefer the hex pads - just slightly. Starting out, it's hard to beat Megs Ultimate Compound / Ultimate Polish.
For anyone that is just starting, I think you should start with polishes with SMAT as in my opinion, they are easy to work with. I don't know about the others but Meg's UC is SMATRight now Im on the fence over Poor Boys, Megs, 3M, or Mothers. Feed back please
A DA can get out 2500-3000 sand scratches if done properly with the right patience. +1 with the Meg's Ultimate polish and compound too! .
If you check youtube do a search for Junkman2000. He has a video on wetsanding that is really interesting. He is using 3000 grit and it only takes him about 5 minutes of VERY CAREFULL sanding to get a big scratch off his corvette. 2500 and 2000 might be overkill for a lot of scratches. 1000 is just asking for trouble imo![]()
Bought one the other day to use with a carpet brush attachment. Used a 20% off coupon
I paid about $50.00 with two year replacement policy. I also rotated the switch to the top.I did the same but mine was on sale and THEN I used the coupon. Total price was around $43.
Has anyone else rotated the motor housing on the HF DA so the on/off switch is on top? After I did it not only made it easier to operate the switch but it also rotated the speed dial and kept it from vibrating over to a higher speed like it was doing the first couple times I used it.
