I would guess because HF is a reseller of oem products. They focus on selling things as low as possible.I have no idea why Harbor Freight doesn't fix this problem.
I went ahead and ordered a 5" backing plate, which I don't have yet, to see if that solves the problem. I'd really like to use the Harbor Freight pads because I feel pretty silly buying name-brand, Velcro-covered pieces of foam for $10 each that probably cost $0.50 to manufacture.
Why would you take the chance with cheap pads if you're going to take the time to polish your car??
You can get very high quality 5.5" Buff & Shine pads from Autoality for $6.00 each in a 5 pack and I'm sure Nick will meet or beat that price. And, if you take care of them with proper cleaning and don't try to do an entire car with 1 or 2 pads, they will last you a good long while.
I've always washed my foam pads immediately after use in a sink of soapy water, but I've found them to be too fragile to last through one or two washes. Compressing them to squeeze the water out seems to do the most damage. Cleaning them is also messy, time consuming, and I end up with a bunch of wet towels to wash after drying the pads.
Even after squeezing them out with a towel on both sides, they hold enough residual water that I have to let them air dry for several days before storing them in plastic zipper bags. During that time, they are exposed dust and other contaminants that could cause scratching during their next use.
I'd prefer to use cheap pads and throw them away after one use. To me, cleaning up is the worst part of polishing and waxing, so not having the chore of cleaning foam pads makes things a lot more tolerable. It also gives me the peace of mind that I'm always starting with a brand new pad that's free of any abrasive contaminants that might scratch.
So if you're concerned with not imparting marring you must be using good polishing practices, ie at least 4 pads per step. With a 20% off coupon we're looking at $4.80 per pad--that's $19.20 you're willing to throw away after each polishing step and all while using inferior pads because you don't want to spend a few minutes cleaning your pads???????
Guess I can't argue with that logic!!
I wouldn't waste my money on these HF pads and just buy some pads that have a good reputation that are known to last and perform since you're going to be using them for a good while (no one likes to waste money right?). GG, buff and shine, lake country, and megs all have some solid offerings...
I typically only use one pad for each product I use per job. So if I use Griot's Machine Polishes 1, 2, 3, and 4 (I don't always need all four) plus wax, that's a total of five pads per job in the worst case. That's only about $25 worth of Harbor Freight pads. It just doesn't seem worth $25 to try to save them when I consider the amount of time it takes and the damage washing does to the foam.
I can't imagine using four pads per product. That would probably be more pads than a Harbor Freight store stocks.
I do have to say, though, that Griot's polishes are a good choice for those who reuse pads because they are easier to clean up than other brands I've used.
I never wash my pads I take a razor blade turn on machine and etch the dirty soiled compound from the top.Every day I come home I have to make calls wash towels set up van ,and fill water tank there no way I, gonna wash a couple of pads before u know it its 8:00
....... I can't imagine doing 3 or 4 steps.
In any case, if you use one pad per step you are working inefficiently--pads get saturated with spent product and removed clear and lose their effectiveness even with frequent cleaning on the fly.
Here's an article by Mike Phillips regarding the number of pad to use per step and the reasoning behind it--- http://www.autogeekonline.net/forum...-how-many-pads-do-i-need-buff-out-my-car.html
Cleaning pads doesn't shorten their life, but using one pad for an entire car per step will certainly shorten their life.
If you're concerned about the time it takes to clean pads do a search for "Ghetto Pad Washer." You can build one for about $15 and it makes cleaning pads a snap. After cleaning and sqeezing out as much water as possible I put them between a folded thick terry towel and stand on each pad. Then air dry overnight and they are good to go. Edit: Found the link https://www.youtube.com/watch?v=bkLXeWyxP0E&feature=youtu.be
