- Thread starter
- #21
Either a machine or a LOT of elbow grease is necessary to remove either type of water spot when they are bad. I recommend using a machine. tuscarora dave has the deposit side covered and etchings should come out with more polishing. If your working by hand, expect to work each section for a long, long time. You cannot just wipe-on wipe-off a polish and get great results. Even by machine, bad spots might need a good amount of time, if you haven't got the spots out, your not trying hard enough... Just be careful and persistent. :dblthumb2:
I am getting a machine, the Griots. I dont even know how the thing work, but I am going to give it a try,
They will come out, just check out two of my show and shines that had water etchings/acid rain. One was a black Z06 and the other was an 05 black Mustang. It took time but they were removed.
Where could I find them?
KAWBOY have you tried 0000 steel wool on the glass with a bit of diluted vinegar?
No, I havent. As a matter of fact, I've never used a buffer in my life. It scares the s%$#@t out of me, but I will try. My car looks BAD!
I thank you all for all the help. You are have been great!
Brgds.
