Has anyone topped Sonax PNS with a wax?
Dogfather
I couldn't find anything on this.
I'd like to try their Premium Class Wax (a product I don't see much about) and was trying to think of a good sealant to precede it.
Any thoughts?
Sonax net shield is a stand alone product you can top with a wax if you want but no need really.
No reason to top it, I would only recommend using Sonax Brilliant Shine Detailer if any beading falls off.
Thanks. That's probably why I haven't come across it being used that way.
I suppose it's not the type of product to work into a clean/seal/wax process.
Would the pinnacle souveran paste wax take effect if i top it on sonax PNS? Or should I use souveran for summer and SPNS for winter?
The best feature about Sonax pns is its beading/sheeting/roll off so unless the wax you are using can beat it, I would not top it off.
The only thing I would top it with would be Sonax Brilliant Shine Detailer say every couple of washes, after every wash or between washes you can wipe it down with a good QD.. I also like to use CG Hybrid V7 to wipe it down, its a step below the Sonax Brilliant Shine Detailer, but a definate step above a QD.. None will affect the performance of the NPS
I've used it topped with collinite 915 and works great. As a pro detailer told me, the main use of the net shield is as a preparation for nano lack, increasing its bonding.
If you found a wax that will beat Sonax PNS you wouldn't need it in the first place.:props:
Ive read it was the other way around that net shield was the topper for nano lack...
