The Guz
- Jun 17, 2013
- 8,793
- 69
I am just wondering how the BRS works when using something besides ONR. I know that BRS was supposedly designed to work with ONR but I'm curious to see how it works with other products. Supposedly, ONR brings the dirt particles down to the bottom of wash bucket so you can safely wash the vehicle. Will other rinseless products do the same? I'm kind of hesitant in using other products with the BRS. Appreciate if you can share some of your experience with this.
Works fine with other rinseless washes. Used it with McKee's N914, meguiar's D114, CarPro EcH2O besides ONR.
How much solution do you make for a typical rinseless? Do you measure out how much water or possibly have your bucket marked to a specific quantity i.e. a mark at every gallon? Or do you choose instead to just measure how much rinseless solution you’re putting into the bucket and just sort of eyeball how much water you put in there?
Trying to get an idea whether your rinseless wash can be accomplished with 1 or 2 gallons per wash.
Have the McKee's buckets which are marked. Homie discount. Grit guard in the bucket and I make 3-4 gallons. Dunk a pump sprayer into the solution for a pre-rinse.
I've noticed that there are more options now. I'm also pretty happy with the BRS but just have been hesitant trying something besides ONR with it. Yeah the gold sponge seems awfully similar and I'm not sure if being softer is necessarily a good thing.
How is the new black sponge? It seems like a good product and unlike the BRS, it won't stain (or show the stains) as easily. Not that getting rid of the stains is difficult or anything. It seems slightly more ergonomic as well.
Also, after you use the si02 product with the sponge, do you thoroughly clean it or just rinse it out and go to the next rinseless? I'm kind of weird and would chemically clean the sponge after using a si02 product in it. For some reason I'm under the (probably false) assumption that an si02/sealant infused rinseless will somehow mess up my drying towels and render them useless. So I simply separate regular wash products from si02/sealant wash products. I'm sure its all in my head LOL.
The gold sponge was designed for softer paints in mind. The new TRC black sponge is supposed to be much better than the BRS in performance and ergonomics. The BRS should be cleaned out every few washes with some APC.
The SiO2 won't do anything to the BRS. The solution is mostly water anyway so any SiO2 won't be that durable. Rinse out the sponge and use it again for next time.
