So I'm pretty new to using a DA polisher and have worked on 4-5 vehicles now. I'm using a Griot's GG6 DA polisher.
One vehicle I worked on was my older 99 model white GMC truck. It turned out pretty good considering how scratched and swirled it was, however it took a good while to make progress. I figured it was just too bad for the orange pads and compound I used. I used LC orange and BS orange pads and Wolfgang Total Swirl Remover
Next I tried my wife's 2015 Mercedes C300. It's a metallic blue/gray. It had some scratches, very very minor swirls, but then some spots that looked like a mix of pollutant and water spots. Orange pads did almost nothing. They did take out the very very light swirls/holograms. I then bought some Griot's Fast Correcting Cream. This didn't seem to help a whole lot, so I tried some Griot's microfiber pads. That worked but still took a long time having to go pretty slow and doing several section passes.
Next I tried my father in Law's GMC truck. I think it's like a 2012 or 2013. It's a peal white. I had the same problem as on this as on the Mercedes. I finally got it polished pretty good but it took way to long and too much effort.
The last car I tried was a 2017 Camaro 2SS Metallic Black. I didn't do the entire car but tried a spot since my friend was wanting to try out his Porter Cable polisher. The orange pads again didn't do much. Can't remember which compound we used.
From what I've seen, the orange pads are supposed to correct out swirls and light scratches. However I've found they don't do hardly anything on the scratches I've tried them on and take way too long on the swirls. Is it my correcting cream? Do I need something more abrasive than the Griot's? Is it pads? Technique? I have been using a 3-4 pea sized amounts on the pad and working on an 18" square section. I'd spread out the compound, polish one way, then do it the opposite way and repeat until the compound starts to break down. Maybe 4-6 passes per section. I see other people on here and on the Facebook group that make vehicles look like glass and I'm just not getting that.
Here's a video showing the Mercedes after doing a section. You can still see the spots
