- Thread starter
- #21
Updates for the evening: I borrowed the three-step 3M product (his is the 3000 version, not the new EX or whatever).
Step 1 with the GG was OK, maybe a bit better.
Step 1 using my cheapo Bosch cordless drill removed the swirls left by the above, but also the swirls left elsewhere by the Menzerna.
Step 2 with the Drill looks basically done.
Haven't tried Step 2 with the GG, because the GG has not ever produced reasonable results with any compound or polish.
I assume Step 3 will go well, haven't even tried it. Honestly, the surfaces I've tested look done, but I'm sure I'll do Step 3 once everything is evened out up to this point.
So first off, big thanks to everyone for the advice and encouragement. I think I'll stick to this program for this set of instruments. Happy to post further updates on it all (but I need to re-spray one of them, so it'll be a week or two).
Second, I'm not actually sure what to think about the GG 3" tool. Everything it does poorly is done better by my cheap drill with a 3" pad. I'll call to see if I can return it, but it's used and I'm not even sure I have all the packaging and stuff. ah well, live and learn I guess, on that.
Thanks again!
EDIT: I tried to include an image of the "good" result above, but I've hit my 5 image upload limit, I guess? I'll see if I can find a work-around, but here it is on Imgur if you want to see:
Imgur: The most awesome images on the Internet
Thanks again!
