Having trouble with 105/205
Dark Knight
First off i want to say i'm not new to detailing but i am new to the 105 /205 combo.
Iwant to start off by saying i washed and clayed the truck the next step was onto the
105/205. I am using a Griots DA with LC CCS orange and white pads. In the garage it
looks great but when i pulled the truck out in the sun you can still see the cobweb
swirls.
I am using light to moderate pressure on the machine. Should i step down to a 5inch
pad? As i'm using a 6inch now or does anybody have another solution to why my
results are not coming out like everybody else that is using this combo.
The truck is white and the imperfections are not noticable inside the garage but very
noticable in the sun. Somebody please tell me what i'm doing wrong.
How many section passes are you doing?
Do you have any pictures of the defects?
What is the vehicle?
It is hard to tell what the problem may be without more info.
I'm going 2-3 passes per section.
I cant seem to capture the defects in the paint due to the truck beeing white.
The truck is a 06 F 150.
Are you moving the buffer 1 inch per second and applying 15 lbs of pressure? 90% of the time when I have people asking these same questions, it's because of not doing the above two things.
This sounds like a technique issue. See below for problems and solutions
A Mike Phillips article:
Here's a list of the most common problems
  1. Trying to work too large of an area at one time.
  2. Move the polisher too fast over the surface.
  3. Too low of speed setting for removing swirls.
  4. Too little pressure on the head of the unit.
  5. Too much pressure on the head of the unit so the pad quits rotating.
  6. Not keeping the pad flat while working your product.
  7. Too much product, too little product.
  8. Not cleaning the pad often enough.
Here's a list of the solutions in matching order,
  1. Shrink your work area down, the harder the paint the smaller the area you can work. The average area should be and average of about 16" by 16" up to 20" by 20" or so. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot.
  2. For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's really easy to move the polisher too quickly because the sound of the motor spinning fast has a psychological effect to for some reason want to make people move the polisher fast. Also the way most people think is that, "If I move the polisher quickly, I'll get done faster", but it doesn't work that way.
  3. When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting, again... this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad rotating over the paint as well as the combination of time, (slow arm speed), together with the diminishing abrasives, the foam type, and the pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches. It's a leveling process that's somewhat difficult because the tool is safe/gentle while in most cases, modern clear coat paints are harder than traditional single stage paints and this makes them hard to work on. This is also why people get frustrated, they don't understand paint technology, all they know is their paint swirls easy and getting the swirls out is difficult and thus frustrating.
  4. For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much pressure and the result of too little pressure is no paint is removed thus no swirls are removed.
  5. Just the opposite of item #4, people think that by pushing harder on the polisher they can work faster and be more aggressive, but the truth is the clutch in the tool is a safety mechanism to prevent burning and will cause the pad to stop rotating, thus less cleaning or abrading action and once in a while this will lead a person to then post on the forum something like this, "Hey my pad doesn't rotate". There needs to be a balance of enough pressure to remove defects and keep the pad rotating but yet not too much pressure as to stop the rotating action. This balance is affected by a lot of things, things like type of chemical, some chemicals provide more lubrication and the pad will spin easier, curved surfaces or any raise in body lines will tend to stop the pad from rotating. This is where experience on how to address these areas comes into play or you do the best you can and move on. It's not a perfect tool, nor a perfect system, but it's almost always better than working/cleaning by hand.
  6. Applying pressure in such a way as to put too much pressure to one side of the pad will cause it to stop rotating and thus decrease cleaning ability.
  7. Too much product over lubricates the surface and this won't allow the diminishing abrasives to do their job plus it will increase the potential for messy splatter as well as cause pad saturation. Too little product will keep the pad from rotating due to no lubrication and there won't be enough diminishing abrasives to do any work. Again it's a balance that comes with experience, or another way of saying this would be it's a balance that comes with hours of buffing out a car to learn what to do and what not to do. Information like what you're reading here is just an edge to decrease your learning curve. Hope this is helping.
  8. Most people don't clean their pad often enough and most of the time the reason for this is because they don't know they're supposed to clean their pad often and they don't know how to clean their pad. Again, that's why this forum is here to help you with both of these things. You should clean your pad after every application of product or every other application of product, your choice, most of the time cleaning your pad after every other application of product works pretty well. It enables you to work clean and enables the foam pad, the polisher and the next application of fresh product too all work effectively. How to clean your pad will be addressed below sooner versus later, but not at the time of this posting. (Sorry, I'm behind a keyboard, not a video camera
The first 4 are the most common. Can't tell you how many times we hear a comment like this from someone in the garage after demonstrating the correct technique
"That's what I'm doing wrong"
The dual action polisher is a gentle tool, that's why people like it. People are afraid of machines because they're worried they're going to either instill swirls or burn through the paint. When they learn that this is pretty hard to do with this machine, so after enough research or after watching a demonstration they learn to trust it and try it.
Summary: People like the dual action polisher because it's oscillating action is safe and gentle to the surface.
Now follow me on this...
For the same reason people love the dual action polisher, (it's safe and gentle), a segment of people get frustrated with it because it won't remove all defects all the time. It won't tackle serious or deep defects quickly and easily. It won't always work on really hard paints. So for the same reason people love this tool, they also hate it, they just don't know why. Maybe after reading this post they will understand.
This is the reason this thread is so widely read and you can learn a lot from it if you'll only take the time to read through it.
PC + 83 not "Cutting" it! - The Limits of the Dual Action Polisher
Even the pictures of the paint on the white truck on the first page and the story behind it are powerful and REAL (This writer took them and did the testing with both the G100/PC and the RB).
When the G100/PC with a strong cleaner/polish like M83 and our W-8006 polishing pad doesn't remove the defects to your satisfaction or within an acceptable time limit the answer is not to get more aggressive with a more aggressive pad or chemical or both, the answer is to switch to a more powerful machine like the rotary buffer and or take the car to a Pro who knows how to use a rotary buffer, or learn to live with the defects.
Hope this helps... Mike Phillips
Office: 800-869-3011 x206
[email protected]
those pads are big, thick and the clear is hard. Not surprised you aren't getting anything out. The moderate pressure you are using is probably only enough to overcome the thickness of the pads and their large size.
Do you have 5.5 inch pads and a 5 in bp? If so then make the switch. Hopefully they are the 7/8 in flat pads. Even then, you will probably need 15 lbs of pressure at speed 5.5 for the first few passes.
Do a test spot and experiment with pressure, passes, etc. After the 105 flashes, apparently you can spritz with distilled and keep going for a few more passes to get some additional cut if required.
A test spot would also save you from doing the entire car, then finding out you still have swirls.
I am using the machine on speed 5.
I think that most of my problem is moving the machine to fast and working to large of an area. The 6inch pads do seem a little big and bulky i think i'm going to order a 5inch backing plate and pads.
Has anybody used the Megs Microfiber system with 105/205 instead od the 300 and 301. It seems to me that more people are getting better and faster results using the microfiber pads over the foam pads.
DK....do a search with those key words. There are many using that or a variation of that with the MF cutting pad and a foam finish pad.
like others said. always do a test spot. do a 12"x12" section with different pads, products, pressure, passes ect. see what works the best. tape off these sections so its really clear. i always do 5-6passes. 2 passes is nothing you won't get any results with that. count your passes and slow arm speed. Work in small 12"x12" sections. also use speed 5 on your DA.
get surbuff pads if you want sometime more agressive that will finish down really well with m105
there's prolly nothing wrong with the way youre doing things, I polished my F 150 a few weeks ago ( its the hardest clear Ive ever seen ) and I had to use 3M super duty compound to get the swirls out
One of the things that helped me the most with a similar problem your having was to take a sharpie marker and put a mark on the edge of the backing plate. As it turns out I was actually using too much pressure and the DA was just jiggling instead of rotating. Once I figured that out the finish I was looking for started to shine through. Then there was the dust....
