HD Nitro Seal
The glossiest finish I have experienced is from exo. That said the polishing is the most important step to extract max gloss
If you go to Autotopia to the forums tab, 3D HD has a whole area. I am a Fan. I have UNO and Speed. If its hot where your at,, these are for you man! Long work times,, and btw DO NOT PRIME PAD. use aobut 8 pea sized drops and start. LESS IS MORE. Check your PM's ill drop you a note.
Thanks beamers. I've been over there and have done a lot of reading there about it.:props:
I did a review of Nitro Seal, I am sure you can find it on some of the other forums. I thought it was a good product. It does take longer applying as it is two part. Put to much part B on and it's a little hard getting off. HD polish is my go to finishing polish.
HD polish replaced mezerna 85rd for me. Same results and much easier to use.
