Ive got the gg 3" and it does work for wet sanding lights. Dont expect much paint correction (can do light tasks on high speed and orange pad), but it is still useful (3" soft brush for leather cleaning is another favorite use).
If you have a compressor, the 3" pneumatic DA sander from Harbor Freight is $25
It is what they used down at Meguiar's HQ for demo nights
Theirs has a Rupes inline air regulator
No compressor. Not sure which way to attack these lights. Initially I even thought that there might be a defect with the Hyundai headlight lens. The gg6 should have plenty of power for sanding headlights, shouldn't it? I may try the 3" bp and attachments on the gg6. Really don't want to waste more sandpaper by "experimenting." (at least not this week lol)
Try the 3M refill kit and use the papers on your 3" BP and DA
$12
P500, P800, P3000
3M Headlight Lens Refill Kit 39049
What is the best way to address deep scratches from automatic car wash brushes in tight areas that have a rubber edge?
I always tape up to the edge of rubber seal. 800/400 will usually clean those up, depending on how much oxidation is there in addition to the scratches. I'm almost willing to put the mortgage that it's a Mustang in the pic because they're notorious for scratches on the side of the headlight closest to the wheel wells.
Funny, I've had zero issues using the GG3 for damp-sanding, even through headlamp clear coats with 320 and 500 grit papers. @OP: Perhaps you just need more aggressive discs to cut the clear. Usually oxidized and failing headlamp clears come off easily, intact clears are thick and tough.
