Headlight sealant: spar urethane vs. opti coat 2.0
HotRod
Well, I have concluded my original spar urethane longevity test with the two year update. http://www.autogeekonline.net/forum...eadlight-restoration-new-uv-sealant-idea.html And now I am ready to try the unpolished version, and see how long it lasts, but I am testing it head to head against Opti Coat 2.0 to see which lasts the longest. The test car is the same car in my original thread, a 1998 Mercury Grand Marquis that does not get too much washes or wax jobs, plus it sits outside 24/7. The passengers side light will be treated with the Minwax spar urethane(unpolished version) and the drivers side with the Opti coat 2.0.
Minwax Spar Urethane/mineral spirits VS Opti-coat 2.0
Here is my step by step process for this test.
Both lights were washed, and then masked off with painters tape to prevent scratching paint and chrome trim.
Here is my sandpaper of choice, 1500, 2000 and 3000. Anything more aggressive and it would have been overkill, the old spar urethane treatment is very soft and thin, so it was very easy to remove.
I use this meguiars sanding backing pad to aid in the wet sanding process.
I soak all the sand paper in a bucket of water with grit guard. My chosen soap for lubricant is Meguiars hyper wash.
I soak the light down by spraying water before wet sanding.
And begin sanding, starting with 1500, 2000 and finish with 3000.
Close up picture of sanding "slurry" remnants of 2 year old spar urethane.
Finished sanding.
Finished sanding.
Now here is where the whole process changes, the opti coat side needs polished before application and the spar urethane does not and is ready for application now. Here is my polisher of choice for the opti coat side, my dewalt rotary with orange and black pad.
The compound and polish I used for the opti coat side is Megs M105 and M205.
And here is the drivers side light after polishing and ready for Opti coat 2.0. But first it needs a wipe down with IPA to remove all polishing oils, and insure a proper bond.
Here is the finished side of the Opti coated headlight. I applied it with the provided sponge, and basically followed the instruction on the syringe.
Here is my spar urethane supplies, I use a measuring spoon to make sure I get the 50/50 spar urethane/mineral spirits correctly mixed. I use a plastic wax free cup, and use a pop sicle stick to mix everything up.
Here is what the mixture looks like.
And here is my applicator, a blue scotts shop rag folded up.
I wipe the mixture on side to side with the spar urethane. Remember, I did not polish these lights before applying this sealant as it is not necessary and hopefully provides a better "bite" for the sealant and maybe lasts longer as well.
And here is the finished Spar urethane side.
Both lenses look good after the process, but I must say that in my opinion, the spar urethane side looks slightly better than the opti coat side in person. But the real test will be which will last longer. I will keep up on this, and try and take pictures every 3 months and post here, if anyone is still interested. Please keep giving me suggestions on this process, as I am still learning myself. And I encourage other members to do tests like this to get more comparison and get different climates factored in as well.
Agreed, very cool...my money is on the opti-coat though lol...not that i'd offer that to every customer unless it was for more than my typical $50..since you have to compound/polish/IPA....and plus opti-coat is expensive...BUT...might be a nice upsell :)
I really want to try your unpolished sanding-to-urethane approach on a customer's car but am hesitant because it seems likely as soon as the finish sealant fails the light lens is going to get very hazy/cloudy. In other words, the future failure will be very acute and noticeable, instead of failing gradually as would be expected from the polished side. On the other hand, the finish might last twice as long due to the greater surface area to bond with and a heavier coat of LSP.
Very interesting test and I much anticipate your updates.
Thanks you.
This is cool. I can't wait to see how this turns out.
I was looking to try Opti-Coat myself so I'm glad you did this. Besides the longevity of OC cost is the big factor, how many lights do you think can be done w/ one tube?
I think a lot of lights can be done with this size of opti coat, not sure on how many, but you don't need much per light. So it should last along time.
Looking forward to the long term thanks for doing thistest
SUBSCRIBED
The amount of lights that can be done with one tube is enormous. I'm not even going to venture a guess but you could get A LOT of lights out of one tube.
Can't wait to see how this plays out. Thanks for going to all the trouble for doing the test.I have had great results with you original method.
I'd like to add my "Thanks" also to Hotrod. I've been using the spar method about a year now with great results.
Thanks again hotrod!
You do a great job of updating your headlight tests!:dblthumb2:
Awesome idea. You took it to the next logical step. I, too am looking forward to the updates.
Thanks for posting this hotrod. Most of what I have done so far, I won't be able to track long term. I have a couple other long term test jobs to do... just haven't got to them yet.
I had hopes that OC would be the silver bullet... a fairly simple and nearly permanent coating. I've been using it on headlight jobs here and there the past few weeks. One test light I did has me concerned though. It seems to be showing some loss of gloss/clarity... and it's way too soon for any type of deterioration. I'm hoping this is an anomaly or I didn't get it coated well, because I really want OC to work. I was expecting at LEAST a year before seeing any breakdown.
I'll see you in six months, one year, than in two:)
Thanks for doing this again HotRod (and since the Dark of the Moon is coming out), Rodimus Prime?
Hotrod.....What is the method of application for the Opti-Coat? (I've been using the Spar method for a while now and am familiar with that) I'm just wondering if I would need any special tools or anything to apply it, or does it just wipe on like the spar?
Here are the directions directly from the AG store.
Directions:
Polish paint to remove any defects.
Clean surface with 15% IPA solution to remove all polishing oils, waxes, and silicones.
Prime the applicator by making an X pattern across the pad. Only a few drops will be needed for each subsequent panel.
Wipe Opti-Coat onto a single panel at a time in a thin layer using two directions, front to back, and then side to side.
Within 5 minutes, inspect the panel with adequate lighting looking for any thick areas that have not flashed away to clear.
Use foam applicator or paint safe microfiber to even out any areas where you see streaks. This step is key, as any spots not leveled will have to be polished if allowed to cure. Panels will feel a bit tacky and will be self-leveling during cure time, so avoid any unnecessary touching, wiping, or contact to produce the best results.
Repeat steps 1-6 for each panel where application is desired. Not recommended for glass.
Its definitely applied differently than the spar urethane, and it needs a perfect surface, as it does not hide scratches at all. The opti coat does not require any special tools for application, as you just use the provided applicator sponge, however you will need a polisher if you have done any wet sanding.
