Hello AGO!! Collinite 845 filmy haze.
Yeah +1 with Grayhw48 make sure you heat it first to thin out the consistence huge difference. Also make sure you are changing out your towel a lot during your wipe down for clean one and not just moving product around. I would say 8-12 towels depending on how big or tiny your car is. I usually use one new towel for each panel, primary wipe with one towel then clean towel for clean wipe. then next panel use the last panels final wipe towel for its primary wipe then new towel for its clean wipe.
Just asking if you heated the 845 in hot water and shook it up well before you applied it. Makes it a lot easier to apply and get good results.
This is extremely important and it makes all the difference in the world. 845 needs to be in liquid form, not a semi paste! In the summer once it assumes liquid form it will stay there if you store it in the garage. Just bring it inside for the winter.
RamAirV1
