22ple Application Instructions:
-Ensure the surface is cleaned & polished.
-Remove all oil/polishes on the surface by doing an IPA (Isopropyl Alcohol) wipe down. Use a mixture of 50% Isopropyl Alcohol with 50% distilled water.
-Please make sure the surfaces are cool and TOTALLY dry before applying the glass coat.
-Pour a small amount of glass coat liquid onto a foam applicator pad and apply in a straight line motion. Do not over-apply as it does not give you additional benefit, but it might make it difficult to remove.
-Make sure ALL surfaces are covered. You should then buff off the coating with a clean, lint-free microfiber towel within 3-5 minutes in normal room temperature. Should you encounter any dried coating, simply reapply another layer over it and buff. If an area becomes dry / tacky, then it's a sign that you allowed it to sit on the surface too long. We like to use 2 towels for removal. The first for main product removal, and then immediately go over it again with the second towel to ensure that you have completely removed all residue. As a good rule of thumb, apply 22ple to just 2 panels / sections at a time, and then proceed with residue removal. If you extend any more than this, the coating will dry too much and can become tacky.
-Cure time - Do not wash your car or expose the car to open weather element,rain, snow etc for around 8-12 hours.
-After this initial curing time, the car can be washed or driven per normal.
-The full curing time is about 5 days, at which time the full layer of the coat will be hardened and the surface will look its best.
-Do not reuse any applicator pads used to apply this coating. 22ple will dry and harden these applicator pads and if used again they could potentially mar the paint.
