ironman1982
- Jul 6, 2010
- 59
Rasky and any others that own one,
Just got my Highline II meter in today and am trying to calibrate it using the two "standard shims" Can anyone outline the process for us thick skulled individuals? I understand that one shim is Ferrous (Steel I presume) and the other is Non-Ferrous (Aluminum I presume). Both shims are covered on both sides with a plastic film typical of sheet metal. Are you supposed to remove one side's plastic and leave the other on so that the bare side is the zero calibration level and the plastic covered side is the "coated" side which you are supposed to adjust via the mem button to the "expected value"? The only number I could find as a possible expected value from the instructions is "50um" (46um - 54 um) range including the error tolerances. If so, are both shims to be adjusted to read 50um when measuring the plastic covered side? The Fe shim's two coatings appear different from one another so I am curious that if you are supposed to take one side off for a zero side which side do you remove? Also from reading above it looks like you must reset to factory calibration for each material separately. How exactly do you reset to factory settings? Do you measure the shim just to turn the display on then press and hold the "-" symbol till "0" then "00" then "000" appears then just let the meter auto turn off or are you supposed to then at that time remeasure the shim?
Sorry for all the questions and I know to those who own this and know how to use it these questions probably seem idiotic but the instructions are IMHO horribly written and very vague.
Thanks so much in advance for any and all help you can provide and I hope that this can be an educational thread.
