HELP! Can't finish down without micro-marring on 2015 Ram 2500
Was the vehicle mechanically decontaminated? If not you could be spinning the trapped debris on the paint.
What machine are you using? What technique? Are you moving too fast? Remember the product should be doing the majority of the work, you have to let it do it’s job.
What I don't understand is why does the 105 side looks like it finished out better than the 105/205 side?
Regardless of the paint's hardness/softness something doesn't seem right. The 205 should always finish out nicer than the 105.
Agree. On paper M205 should finish down nicer than M105. Hard to say the what and why for all situations when we cannot be there in person.
I’m not 100% sure, but I’m pretty certain that the truck was not repainted. I will thoroughly read through the write-ups.
PM sent with shipping info. Thank you!!
It's Thursday, (I was off work and offline on Wednesday), the order is pulled and as soon as I fill out the paperwork it will be shipped today.
No need to buy another machine...?
That shouldn't be necessary.
Agree.
A long stroke FREE SPINNING random orbital polisher should be able to finish out with the right pad and product.
When it comes to soft paint - my experience is a FREE SPINNING random orbital polisher will tend to finish out nicer and more consistently, (that's 2 things), versus a GEAR-DRIVEN NON-RANDOM orbital polisher.
I shared that back in 2012 in post #4 of this article.
Christmas Detail - Ferrari P4 - Move over Rudolf
I was directed here from another thread....glad I was. This is what you call candy coated, good grief it looks like the paint is "flowing". Amazing work!
Thanks Troy. I don't really like working on cars that sit so low to the ground without a lift. The front air intake scoop was a real pain to buff as I only have one leg to support my upper body while bending over it carefully running the polisher but it all got done.
I have a before video of the horrendous swirls in the paint before I started. In the video I stop while the camera is trained on the front clip showing all the swirls and in the video I say,
"I don't understand how all these cool exotic cars get so swirled-out?"
And... I still don't get it.... :dunno:
This car was in a museum for 20 years so chances are it was simply wiped, and wiped, and wiped, and wiped with who knows what...
What made you decide to finish out with the G110 vs the Flex? Pad size selection or the non forced rotation maybe?
Good question...
I find on softer paints like this car has that the PC style with a Fine Cut Polish finishes out nicer than with the more powerful Flex 3401.
The paint on this car was incredibly soft.
I only did my test spot using the Flex 3401 and end-results were acceptable, I did the 8mm free spinning step just to "make sure".
I also machine applied the wax using the Meguiar's G110 polisher.
Saw this car recently while working on a Maserati, still looks just like it looks in the pictures.
Link to YouTube video remove to reduce redundancy. I did however edit your post to insert the "pure" code for the video. :D
Michael aka "The Guz" brings a great suggestion to this thread for the guy working on the Black Ram and ANYONE that reads this thread into the future. (I always type for the future, never just the moment)
RUPES introduced a new ULTRA FINE CUT polish specifically for SOFT or FINICKY paints. I recently encountered one of the SOFTEST paints I've ever worked on in 30+ years of detailing cars.
Here's the link to my full review. (the only written and photo-documented review for RUPES Pure that I know of for this product)
Barn Find - 1950 Pontiac Chieftain Deluxe Convertible - Extreme Paint Correction
Here's yours truly using the RUPES UNO 1 Pure on the ORIGINAL Lacquer paint on a 1950 Pontiac.
And while I encourage everyone to click the link above and read the entire article for their own benefit and to increase their personal knowledge base, here's what I wrote about soft paint and this new RUPES product.
Soft Paint versus Hard Paint
Generally speaking, modern clearcoats are harder than old school single stage paints with the exception of single stage white paint. Yes I know there are exceptions to the rule and any detailer that has been detailing for a while, like myself, has come across modern cars with soft clearcoat paint. Besides the exceptions, I'll say it again, generally speaking, modern clearcoats are harder than old school, solvent-evaporation single stage lacquers and enamels.
The softest paint
Generally speaking, (and from experience), antique, single stage black paint is the softest paint there is to work on in the history of "the car". When it comes to paint hardness or paint softness, this characteristic is affected by both the resin and the pigment. Paint is at it's core, some form of resin. To give paint or resin color, pigment is added in the mixing stage. Now follow me, some pigments are very hard, some pigments are very soft and of course, some pigments are in the middle. The hardness or softness of the pigment will alter or modify the hardness or softness of the resin.
Examples of hard and soft paints
Single Stage White Paint
When it comes to white paint, the pigment used is a very hard mineral called Titanium Dioxide. Adding this mineral in a powdered form to any type of resin will make the resin very hard. In fact, for the most part I would NEVER take on a job to wetsand and buff a single stage white paint job where the paint is already cured. Why? Because I'll never be able to remove 100% of the sanding marks. Sanding is easy, that's putting scratches INTO the paint. Heck, anyone can wetsand a car. The tricky part is removing the sanding marks.
Single Stage Black Paint
To make black paint, Carbon Black powder is used. Carbon Black in simple terms is soot, like in chimney soot, or the kind of soot you would find accumulating on the underneath side of the home barbecue. It's a very dark, black residue or powder from the incomplete combustion of some other materiel. The other material could be fire wood or when you burn your T-bone Steak last summer on the Weber Barbecue on the back patio.
The BIG PICTURE
When it comes to doing paint correction, knowing the hardness or softness of the paint can help you choose the products, pads and tools you'll use to remove paint defects. BUT - you will never know how hard or soft the paint is on the car before you until YOU do what I call a Test Spot. That is, you test a product, pad, tool and technique that you THINK will remove the defects and leave behind perfectly looking paint and if you have chosen wisely - it works. This is why you also start with very NON-AGGRESSIVE products. If the paint is soft, then the non-aggressive products will remove the defects while leaving the most paint behind on the car to last over the service life of the car. If start with non-aggressive products and find out the paint is hard, you're safe, you can then do another Test Spot and this time, do the test spot in a different place on the and test out more aggressive products, pads or even tools.
If the paint was in fact soft, you will have discovered this by using non-aggressive products and more important you will have done the testing in the safest way possible to protect both you, your business and your reputation and of course, protected the integrity of the paint on the car. When I say protecting the integrity of the paint on the car I mean you will NOT have burned through the paint where you did your test spot.
Doing a Test Spot is the professional approach to dialing-in a process you can then duplicate over the rest of the car. It is also the ONLY way to determine if the paint on a car is hard, soft or somewhere in-between. If you're brand new to paint correction you are missing one component that is also necessary to use a Test Spot to determine paint hardness or softness and that is experience. And the only way to get experience is to buff out hundreds of cars. I know this isn't the answer everyone wants to hear but is is the fact of the matter.
Doing a Test Spot on a 1950 Pontiac Chieftain
One of my go-to products for this type of job is to use a one-step cleaner/wax or as many refer to it - and AIO or All-in-One. A quality AIO uses GREAT ABRASIVE TECHNOLOGY and it will do three things in one step,
1: Paint Correction - the product will remove paint defects like swirls, scratches, water spots and oxidation.
2: Polish - the product will polish or burnish the surface of the paint to clear, smooth high gloss.
3: Protect - the product will leave some form of protection behind on the surface. In the old days the protection component of an AIO was some type of wax. Then science introduced synthetic paint sealants as the component used in an AIO. Now days there are AIO that use some form of nano technology in the way of ceramic for the protection component.
The point being, a great AIO will do three jobs in one step. This is my entry level detail package for people that don't want or need a multiple-step process to get a car's finish to their expectations. All professional detailers and even enthusiast detailers should understand what this type of process is and how and when to use it.
First Test Spot
For the first test spot I used a popular AIO and while it easily removed the swirls, scratches, water spots and oxidation it also left micro-marring in the paint. The results from this Test Spot told me not only was the paint soft it was STUPID SOFT. I don't use the term stupid soft to describe paint unless it's accurate. This paint was so soft that even using a great AIO with a super soft foam "finishing" pad, there was still micro-marring being left in the paint.
Second Test Spot
For my second test spot I remember that RUPES had recently introduced a brand new ultra finishing polish called UNO 1 PURE. This product was specifically formulated for super soft, finicky and sticky paints. I wouldn't call the paint on this 1950 Pontiac finicky or sticky but it definitely qualifies as super soft.
I tested the RUPES polish with a Buff & Shine 7" Uro-Tec soft white foam finishing pads. Together, the RUPES ULTRA fine polish and this softest foam pad formula in the Buff & Shine line-up, this is about as non-aggressive as you can get and still have enough cutting or abrading ability to actually remove the swirls and scratches.
RESULTS
This combo did the trick. It removed the majority of swirls and scratches without leaving any micro-marring behind. After PROVING my system, I then proceeded to machine buff the entire car after doing a waterless wash with SONAX Glass Cleaner and claying the paint with Pinnacle Ultra Fine Detailing Clay.
1: The RUPES UNO 1 PURE Ultra Fine Finishing Polish has zero dusting and super easy wipe-off. If you're new to paint correction, these are two characteristics you want in any polish. I don't mind dusting so much, but zero dusting is better than any level of dusting. Easy wipe-off? Bring it on all day long. If you're a seasoned and experienced detailer then you know what I'm talking about when it comes to zero dusting and easy wipe-off.
2: New cars have plastic trim and you want to tape this crud off so you don't stain it if you accidentally get any polish or wax on it. No so with classics like this Chieftain, it has chrome and stainless still trim. Instead of taping it off - you run the polisher over it. Normally it doesn't matter what type of compound, polish or even AIO it is you're using, metal surface just don't care much. Running a buffing pad with any type or brand of polish over metal trim will remove topical staining and contamination, tarnish and oxidation and typically will restore the a clear, clean bright shine. I also run the polisher over all the glass windows. Over time, in the same way paint becomes stained and contaminated - so does every other exterior surface including the glass.
And not only did the RUPES Pure perform as advertised, the LSP I used also did it's thing.
Review: Collinite No. 845 Insulator Wax
BEFORE
The rest of these pictures I took when the car arrived.
First a few outside using bright overhead sunlight to do what it does best - reveal the true condition of your car's paint.
AFTER
Yes, vehicle was properly decontaminated. I was using the Bauer long throw from HF :doh: Making 6 section passes at about 1-2'' per second with light pressure. I just ordered G9 because I want to completely eliminate the machine as possible culprit.
The Blackfire Onestep, white polishing pad, and short throw polisher was exactly what I needed. A big thanks to Mike and everyone that replied!!
attachment.php
attachment.php
Thank you for the update and I’m glad to hear you were able to remove all the micro-marring.
I know a lot of people want to get into ceramic coatings but using BF One Step is so fast and easy.
How did you like the wipe-off?
On a side note...
Dennis Gage called me this last Tuesday to tell me he used BLACKFIRE One Step over the weekend and was seriously blown away by the product.
He loved it so much... I sent him another quart for his other cars. I think I’ve turned Dennis into a Detailer!
:buffing:
Wipe off was super easy. I tried attaching pictures from my photo album, but I don't think it worked. I set the album to public if anyone wants to check them out.
BF One Step to the rescue again! Btw...it save my tail as well with the help of Mike and the rest of the AGO crew!
Jay
