After polishing to remove light swirls, scratches and baked-in mud from my truck, I cant get rid of the haze. It's a 2012 F150 Tuxedo black. It's always been cared for, coated, maintained but after spending several weeks with 90% of it's time being off-road, it was time to do some correcting. It has mud stains that have been baked in the sun and scratches from weeds, bushes, thorns, etc.
So yesterday I washed and clayed the vehicle and wiped down with IPA that I normally use. I started out using a white hex logic pad with Griots Correcting Cream with the Griots BOSS 15mm polisher on speed 5. After 3-4 passes, the imperfections were removed (including the mud stains) from the hood test section. So I moved on and completed the hood. Using the same setup (with a fresh pad), I went to the driver side. For some reason, the residue was VERY hard to remove. I even gave it some extra time to cure. After removing it, there was pretty bad haze. Not too concerned, I moved onto the door. This time it was even MORE difficult to remove and the leftover haze was way worse. Wiped the panels down with my IPA and CarPro Eraser with no change. So I thought I'd change pads.
I tried an orange hex logic pad with Griots correcting cream. Orange hex logic pad with Griots perfecting cream. White and orange hex logic pad with Griots complete compound. No change, the haze was still there. I even tried a blue hex logic pad with Griots correcting cream. Nada. (edit: I also tried a mf pad with perfecting cream). Wiped it down with IPA and CarPro eraser again and still nothing. Out of desperation I tried spraying Megs waterless wash/wax on it. It actually removed much of the haze, but since I plan on coating with CarPro cquartz when I'm done, I cant leave a spray wash/wax on as my lsp. I also tried to wash the panels again using dawn and mf mitt. Haze is still there. It was getting late and I was beyond frustrated so I gave up for the night.
So to start today, I picked up some Megs Ultimate compound and Ultimate polish to see if that would help. Nobody had 105 or 205 on the shelves and of course I cant order anything online in time.
The mud stains that were removed from the hood yesterday, are now back! I dont get it! Any suggestions? My only thought for today is to slow the speed down on the polisher.
I tried to get the haze with the camera, but it was difficult to capture...this is the best I could do:
View attachment 67700View attachment 67701View attachment 67702View attachment 67703
