Coach Steve
- Jun 12, 2013
- 410
2003 Camry
Factory paint
Original owner
Always garaged until 2013
This maroon beauty was brought to me for interior service.
This car shows nearly every stage of failing/failed clear coat. seriously, it could be used for training! In addition, it has an anomaly I've never seen before and I'm hopeful you can shed some light on what's going on here.
At first glance, it looks very much the way aged, worn fiberglass looks when the gel coat has failed and the fibers begin to stick through. As you get closer, it looks more like someone used the hood as a cutting board while cutting lots of vegetables. (Sorry, that's the best analogy I could come up with). :laughing: An even closer look reveals that the paint has released from the hood much like you would expect to see when paint won't adhere to the intended media due to it being contaminated.
The weird thing is, this vehicle was not painted consistently. Most parts of it are base coat/clear coat but the hood and roof appear to be single stage. The bumpers and trim pieces are def single stage as you would expect. The other weird thing is the paint in the pictures, although raised up and peeling back, isn't brittle. I thought for sure I would run my hand over the area and all the raised points would be leveled. It's not brittle at all. In fact, I had to actually try and break one of them to level it.
Hopefully, I've explained the situation well enough that you can get a clear idea of what's going on here.
The pics are hi def so be sure to view them full size to really get the true perspective.
Thanks!
Factory paint
Original owner
Thanks!
