Hey, how did you guys know
Collinite 845 is one of my favorite waxes?
I hear allot of disappointments when applying
Collinite 845 by hand because it sort of difficult to get thin enough. When applying by hand you really need to focus on using a very small amount. If you question whether you're applying it too thin then you're probably just about right.
If too much
Collinite 845 is applied it'll seem like it's sticky or tacky never wanting to completely haze. Additionally, wiping or buffing becomes a sticky mess but as the excess is removed you should see that the buffing becomes easier and that gorgeous gloss comes through.
For years I applied wax by hand because "by hand" is synonymous with the very best...in this case it could not be further from the truth. I remember waxing being a major pain in the butt because removing wax meant allot of hard work and towels. I also remember allot of product ending up on the towel thus wasting much of it and the hard earned cash I payed for it.
Once I realized that waxes were meant to be applied
THIN everything seemed to fall right into place. If I took my time manually applying the product and getting it
THIN, I generally achieved good results.
One day I decided to try applying
Collinite 845 with my
Porter Cable 7424 dual action polisher and a soft red pad... I could not believe how easy it was and how thin I could spread the product film. A new approach was born!
rops:
When you think about it, just how thick or how thin is that layer of protection we leave on the paint after buffing? I can tell you it's so thin it's probably not able to be measured accurately.
Here's an example to give you an idea of how thin this layer is.
One of my responsibilities is the engineering and development high speed precision metal stamping processes. Typically I deal in real life dimensions as small as 0.00002 inches, that's 20 millionths of an inch. While you might be surprised, your touch is sensitive enough to be able to detect about 0.0002 of an inch just by sliding your finger across two uneven surfaces. That's 2 ten thousands of an inch!
Where am I going with all this you might be asking yourself? It illustrates how thin the wax or protective coating really is that's left after buffing...
THIN is in boys and girls.
