SortaFastRacing
- Sep 4, 2018
- 13
I was in the garage this weekend doing a 1 step paint correction and ceramic coating on my friends 2008 G35S and my wife comes in, 8 month old in hand, to urgently get my attention mid section pass. So I threw my poor Griot's polisher down and ran outside to find my neighbors house on fire. I've never seen anything like this, really makes you think you know..
Anyways, here's my issue. You can see the fire department used 2 hoses, one from the truck and one from the hydrant down the street. They say it started as a dryer fire and I don't know how many options they have for chemicals on the truck or in the hydrant but I do know that different chemicals are used for different types of fires. the wind blows heavy from the west which is from left to right side of the first picture here. That's my house on the right and my 2017 Blue 4-Runner in the driveway just out of the frame. I would've pulled it in the garage but my clients G35 was taking the space.
All those white dots are from the hoses that put the fire out.
A close up of the rear driver side door.
The hood after ONR pre-rinse, wash with The Rag Company Minx towel, flip to clean side - added pressure with Minx
The passenger side wasn't so bad because the way the wind blows.
This truck was recently 2-step compounded and polished with Maguire's UC and UP then coated with Blackfire Ceramic Coating and protected with Blackfire SiO2 Spray Sealant.
I tried to clay the driver side rear window with fine grade clay to see if it would help take those spots off - it sort of worked, maybe took 30-50% of the spots off. Tried the same thing on a small area of the driver rear door, same result sort of. Had to use a lot of pressure for clay - which is kind of uncomfortable you know, I don't want to ruin the coating.
I would like to preserve the coating if possible, I have a ton of the Blackfire SiO2 left over so I don't mind having to reapply that, but I need a way to get these spots all the way off. A lot of pressure and a finger nail seems to do the trick, but there's no way in hell i'm gonna go around and finger nail every little spot haha
Sorry for the long winded story... any ideas?
