- Thread starter
- #21
The finish polish(megs 205)will indeed remove and strip what wax and sealer you have on there. So I would go right to the 205(or whatever finish polish with abrasives you choose). I have tested a few of the Wizards polishes out so I am somewhat knowledgeable about them. They do indeed cut well but do not finish so well IME(like you are experiencing).
Anyway if you choose 205 try a test spot like Mike has suggested then look at it from different angles and lighting. Then if that is satisfactory go to your next step: The Klasse or 845 and have another look. Good luck and keep us posted!
Ok- So the 205 is finer than a swirl remover?? I guess I had thought swirl remover was finer than compounds were...
I think I'll pick up some 205 and go at it with that, then finish up with the 845. I'm not sure if I feel like doing the Klasse steps in the middle. I think I'll test an area, and pull it out into the sunshine this time..... Last time it was raining all weekend, so I kept it sealed up in the garage while I did the work.
