HELP: How to remove Tire Coating
TuxedoTaurus
So my tires have a few coats of the TW tire coat (can stuff).
Is there a way to remove this stuff with out damaging the tire using a wire brush as I have seen recommended?
The last coat was applied over a year ago, and the car has sat for almost all that time.
Just curious, why do you wanna remove it? Pics? I ask because I'm a HUGE fan of the other TW tire coating, the one that comes in the box w/ the tire cleaner, coating ( 8 oz bottle, liquid) a pair of gloves and the special applicator.
I will take some tomorrow. It is brown and a lot of build up.
I know in the other thread you mentioned trying to top it, I don't know if you tried it but it has not worked for me. I tried Meg's Endurance and Hyper Dress (4:1 dilution) and both flung off even after at least an hour dry time.
Only effective way I've found is 3000+ PSI pressure washer and a lot of time.
Sent from my SAMSUNG-SM-G900A using AG Online
I'll give it a whirl, maybe try a fine spray nozzle than the one I use on the cars
Same here. It's impossible. I gave up several months ago. I have come to the conclusion that it is just clear coat spray paint.
I have a technique that worked to get some very nasty 3M adhesive off paint. Dunno if it works on tires - but I think it's worth a shot.
You get a MF wax applicator pad (like the square ones at AG), then dampen it with mineral spirits. After that, add a few blobs of compound to the working area of the pad. Use the pad as a scrubber. The combo of compound abrasives and MS seem to really do a lot of removal work. Remember, compounds are like liquid sandpaper. So, you want an aggressive compound here.
I can't see compound abrasives scratching a tire too bad. I can't see a little bit of MS damaging a sidewall either. I just would clean it well with APC after.
Another possibility would be a Magic Eraser.
After you get this Turtle mess off - check out Tuff Shine. TS is removable by scrubbing the tire with their cleaner. However, you never need to remove it - because it doesn't "brown", peel, or turn to sticky goo. I've had it on tires for over a year (it has been topped off) - but tires have never been scrubbed and look good as new.
From what I've read about the tire coating it seems to me its the aerosol coatings that seem to be the problem, both Tuff Shine and TW, I haven't heard any issues so far with the TW tire coating that's in liquid form. I'm a couple monthes into using it (TW liquid coating) and have had NO issues.
I actually had no issues with the can stuff. I may try the Liquid, it looked tempting at Autozone, but right now I'm over it.
You might want to try something that dissolves paint, because that's exactly what that stuff is.
Paint for your tires!!! I remember going to the auto parts store with my Dad when I was kid in the 80's and they had a can of stuff to paint your tires, LOL!
I'm sure they add a flexing agent but I just don't know how this could be good for your tires as the rubber can't breathe and would dry rot early, atleast this seems to me would be the case, I don't know.
I'll stick with the TW kit I'm happy with it for sure!
Aircraft Remover should dissolve it. Who knows what it will do to the tire though.
People use it to remove clear coat from their wheels.
I wouldn't risk that unless the tires are close to needing to be replaced, then go for it and report back the results!
sorry I'm a little late in the game; what's "TW"? I haven't seen the full name mentioned anywhere in this thread (other than TS which is Tough Shine, and what brand is that BTW?)
I've used a Griot's Garage 3" yellow scrub pad on my DA with some all purpose cleaner and that did the trick for me. Only took me about 5 minutes per tire.
what about using purple power? (so long as you don't get it on the painted surfaces (or if your wheels are painted, then forget PP)
"LIKE DISSOLVES LIKE"
Worth a try...IMO.
I agree with this, one swipe should remove whatever you have on there and you can then start anew.
