HELP: How to remove Tire Coating
I was hesitant to put a solvent on the tires. I did have some Amazing Roll-off. Went through three sessions of scrubbing and blasting with 2400psi pressure washer and an almost closed fan nozzel.
Needless to say after an hour no more coating.
•Glad you were successful in removing the tire-coating!
•However, IMO:
-You did use a solvent.
•Ethylene Glycol has several uses:
-antifreezes;
-hydraulic brake fluids.
-solvent
•Amazing Roll Off contains Ethylene Glycol.
