ironsurvivor
- Jul 19, 2013
- 78
I recently got a new 2013 mustang in black. And I've worked to keep it clean. I got a Porter cable 7424xp because I noticed slight swirls (probably from not using grit guards, which I now use) I used a meguiars yellow pad with m205 for correction about a month ago and it polished it beautifully but I couldn't tell you if I removed anything or not. Well since I'm noticing swirls now and have learned a lot in that time. I tried again with the same products in a test spot and didn't notice much difference. So I was going to buy pinnacle advanced swirl remover and finishing polish and try that out with an orange ccs pad and then the finish polish with the white ccs pad. I'm just scared that I will wear the clear coat down too much. Could you please put some of my worries to rest? Im not going to be doing this often if i can really correct it this time.
