PearlWhiteGT
- Sep 2, 2008
- 149
I'm getting the Flex 3401 & have some PoorBoys SSR2.5 & SSR1. What else do I need to make this car look better than new??? Exterior.....
Did you get any pads?
- car shampoo
- clay bar and lubricant
- pb white diamond
- wg sealant
- liquid souveran
I assume your car is pearl white.
The car is red. The flex comes with a couple of pads. So Natty's blue & P21S Gel are next. What clay bar & lubricant would be good? Would surk city speed demon or FK 425 help with drying? I also want to get a cobra supreme guzzler.
Yeah your process is fine. Just my personal preference, but I don't use glazes. All glazes do is fill in scratches that were not removed. After a rain or wash, they are revealed again. Just take your time with the SSR 2.5. If you don't get all the swirls out with one pass, don't be afraid to do another. Your SSR 1 will remove the marring from the 2.5. Then you can add your sealant, and then you can top that with your LSP.
If the glaze is sealed in by applying a wax/sealant on top of the glaze will it still wash away that quickly?
:whs: Don't hide them, correct them. The extra step of glazing is almost the same as a extra step of correction(polish). Get rid of them with the extra step.Yeah your process is fine. Just my personal preference, but I don't use glazes. All glazes do is fill in scratches that were not removed. After a rain or wash, they are revealed again. Just take your time with the SSR 2.5. If you don't get all the swirls out with one pass, don't be afraid to do another. Your SSR 1 will remove the marring from the 2.5. Then you can add your sealant, and then you can top that with your LSP.
