HELP;....MOBILE DETAILERS using 12 VOLT PUMP FROM TANK TO PRESSURE WASHER
215Detailing
HELP NEEDED with fittings, store, size and part numbers with description if able example of how I want set also may use a filter and CR SPOTLESS WATER SYSTEM down the line
Your best selection for fittings is going to an ace hardware. They have a much better selection of odd ball size fittings then Home Depot does
When I set up my 12 V on demand pump in my trailer I had troubles as well trying to get the pump fitting to work with a traditional garden hose fitting...
Thanks WindyCity hope to visit ACE HARDWARE STORE this coming weekend
I have a Shurflo pump, 12v, and used fittings/adapters from Lasco.
Lasco 15-1635 PVC Hose Adapter with 3/4 inch female Hose Thread and 1/2 inch male pipe thread
Lasco 15-1631 PVC Hose Adapter with 3/4 inch male Hose Thread and 1/2 inch male pipe thread
I used those to connect to the Shurflo (94-591-01) Pump Silencing Kit (essentially just some short hoses).
All of my items were bought through the online retailer that is pretty "amazing" with their "prime" delivery service ;)
much appreciated exactly the type of input I was searching for thanks again JustJesus
