Help! Uber compound is getting the swirls out.
The Op's questions and results mirror what I was talking to Jordan from Flawless perfections about to a T. What he says I have done is get all the superficial stuff off, and now I can see everything else really good! LOLOL So when I get the chance I'm going to go with the yellow and then a white pad. I think that should do the trick. Great Thread, Great Question. I was going to ask same thing if I had not talked to Jordan for an hour or so on FB LOL :xyxthumbs: (Its super shiny though, I can say that for sure!)
Try the wool pad with the compound and a heavy cutting foam pad with a lighter compound. Then a polishing or medium cutting pad with polish like 205. I had my boy do this today on his beat up paint and it was spotless!!
Like mentioned before, switch to MF pads. Both Meguiar's and BnS pads are phenomenal. My last few details have been Fords with rock hard paint, and even yellow LC pads weren't getting things out. Then I switched to MF pads, and the defects just melted away!
Instead of buying a bunch of new polishes, polishers, and pads try this:
1. Slow your arm speed to 1" a second.
2. Add more downward force to the polisher.
3. Max the speed out at 6
4. Shrink your work area by half.
5. Use slightly lest compound, but add a spritz of DI water.
Very good advice and the key to working out stubborn defects assuming all other factors are in order.
To the above point, years ago I wrote a troubleshooting guide for PC style tools, it should be included with every PC/Griot's/Meguiar's DA sold just to give those that don't get on forums some tips to help them be successful because besides the tool, pads and good abrasive technology, the next most important factor is technique.
I'll include it in this thread...
Yes rids are there badly..
How did they get there? These deeper scratches?
but, it still has it fair share of light scratches. But random here and there, not consistent. I rub over them and honestly it feels like the compound should pull them right out.
And a compound will take them right out using good technique. I think after you put some of the suggestions provided in this thread into practice you'll see them disappear.
Show car results on a daily driver is going to only go to waste, instead polish the paint and leave the RIDS.
That's the advice I tend to give for people working on daily drivers. Heck it's the same advice I give to myself for my daily drivers. Practice what you preach and all that...
If your are trying to get results like the pros are you going to maintain the car after?
Great point.
Removing defects is the first battle. Once you win this battle the second battle is maintaining these results and this can be a challenge if the car in question is in fact a daily driver. Especially if the car in question is NOT parked inside when it's not in use.
For those reading this into the future, here's the link to explain everything you ever wanted to know about RIDS
RIDS = Random Isolated Deeper Scratches
RIDS - The Definition of RIDS and the story behind the term...
DA Polisher Trouble Shooting Guide
Tyler, age 15 removing swirls using a Porter Cable 7424XP Dual Action Polisher
When you're first starting out machine polishing and learning to use a DA Polisher it's common to have questions about your results and your results are directly tied to your technique.
Here's a list of the most common problems,
1. Trying to work too large of an area at one time.
2. Moving the polisher too fast over the surface.
3. Using too low of speed setting for removing swirls.
4. Using too little downward pressure on the head of the polisher.
5. Using too much downward pressure on the head of the polisher so the pad quits rotating.
6. Not holding the polisher in a way to keep the pad flat while working your compound or polish.
7. Using too much product or using too little product.
8. Not cleaning the pad often enough.
Here's a list of the solutions in matching order,
Shrink the size of your work area down. You can't tackle to large of an area at one time. The average size work area should be around 20" by 20". Most generic recommendations say to work an area 2' by 2' but for the correction step, that's too large. You have to do some experimenting, (called a Test Spot), to find out how easy or how hard the defects are coming out of your car's paint system and then adjust your work area to the results of your Test Spot. The harder the paint the smaller the area you want to work.
For removing defects out of the paint you want to use what we call a Slow Arm Speed. It's easy and actually natural for most people new to machine polishing to move the polisher quickly over the paint but that's the wrong technique. One reason I think people move the polisher too quickly over the paint is because they hear the sound of the motor spinning fast and this has psychological effect which causes them to match their arm movement to the perceived fast speed of the polisher's motor.
Another reason people move the polisher too quickly over the paint is because they think like this,
"If I move the polisher quickly, I'll get done faster"
But it doesn't work that way. Anytime you're trying to remove swirls, scratches, water spots or oxidation using a DA Polisher you need to move the polisher s-l-o-w-l-y over the paint.
When first starting out many people are scared of burning or swirling their paint, so they take the safe route of running the polisher at too low of a speed setting but this won't work. The action of the polisher is already g-e-n-t-l-e, you need the speed and specifically the pad oscillating and rotating over the paint as well as the combination of time, (slow arm speed), together with the abrasives, the pad aggressiveness, and the downward pressure to remove small particles of paint which is how your remove below surface defects like swirls or scratches.
Removing below surface defects is a leveling process where you need the abrasives to take little bites out of the paint and to get the abrasives to take these little bites with a tool that uses a Free Floating Spindle Bearing Assembly you need all of the above factors working for you including a high speed setting.
For the same reason as stated in #3, people are scared, or perhaps a better word is apprehensive, to apply too much downward pressure to the polisher and the result of too little pressure is no paint is removed thus no swirls are removed.
If you push too hard you will slow down the rotating movement of the pad and the abrasives won't be effectively worked against the paint. You need to apply firm pressure to engage the abrasives against the paint but no so much that the pad is barely rotating. This is where it's a good idea to use a permanent black marker to make a mark on the back of your backing plate so your eyes can easily see if the pad is rotating or not and this will help you to adjust your downward pressure accordingly.
Correct technique means finding a balance of applying enough downward pressure to remove defects but not too much downward pressure as to stop the rotating movement of the pad.
This balance is affected by a lot of factors like the lubricity of the product you're using, some compounds and polishes provide more lubrication than others and this makes it easier to maintain pad rotation under pressure.
Another factor that can affect pad rotation are raised body lines, edges and curved surfaces as anytime you have uneven pressure on just a portion of the face of the pad it can slow or stop pad rotation. This is where experience comes into play and experience comes from time spent behind the polisher.
Applying pressure in such a way as to put too much pressure to one edge of the pad will cause it to stop rotating and thus decrease abrading ability.
Too much product hyper-lubricates the surface and the result is that abrasives won't effectively bite into the paint but instead will tend to skim over the surface. Overusing product will also accelerate pad saturation as well increase the potential for slinging splatter onto adjacent panels.
Too little product will means too little lubrication and this can interfere with pad rotation.
Again there needs to be a balance between too much product and too little product and finding this balance comes from reading articles like this one, watching videos an most important, going out into the garage and putting in time behind the polisher and as you're buffing with specific product and pad combinations, pay attention to pad rotation.
Most people simply don't clean their pad often enough to maximize the effectiveness of their DA Polisher. Anytime you're abrading the paint you have two things building up on the face of your buffing pad,
  • Removed paint
  • Spent product
As these to things build up on the face of the pad they become gummy and this has a negative affect on pad rotating plus makes wiping the leftover residue on the paint more difficult. To maintain good pad rotation you want to clean your pad often and always wipe-off any leftover product residue off the paint after working a section. Never add fresh product to your pad and work a section that still has leftover product residue on it.
Pad Cleaning Articles
Why it's important to clean your pads often...
How to clean your foam pad on the fly
How to use the Grit Guard Universal Pad Washer
Tyler, age 15 machine applying a paste wax using a Porter Cable 7424XP Dual Action Polisher
:buffing:
Sorry for the late update, life and work has been keeping me busy.
I'm going to start back on the car in the next couple of weeks. For Mikes question about the RIDS.The car was bought as a demo with 6K miles on it. It was pretty much new, but as we all know how dealers take care of cars..
I'm going to order a yellow pad and try the Uber Compound ago on the hood and go from there. I will re-read all the comments again to get a better understanding.
1 quick question. After the initial process and applying the paint sealant. It was so smooth for about a week, and after than it's like I never touched it.
Is the Wolfgang paint sealant not enough? Should I put wax on that also?
Well in my opinion, why not polish up the paint.
But if you chase every swirl, scratch, etc... And the washes are still being learned then. You might be taken to much paint off in the long run.
Just shine up the paint, by polishing it, and go from there.
If you do want to chase all the swirls and scratches on a DD, then why not opti coat?
Art makes a good point, I said just yesterday do what you can, do all you can and live with it, now if it's a classic then I'd push my limits.
If you really want some cut than get the Meguiar's 105, aggressive pad then follow with polishing but again as Art said how much paint are you willing to sacrifice some clear?
At times I find that even with the Uber I still end up with swirls, I don't go to the 105 I just live with it, now scratches is different, 105 is king in removing scratches IMO.
Someone else gave you good advice, try the purple wool pad using the Uber, if the swirls are still present be ready to remove more clear than you want.
I always start with the least aggressive compound and pads and work myself up to the Uber , if that doesn't work I stop and enjoy the shine:dblthumb2:
Sealants won't stay slick forever. Get yourself the WG Spray Spritz Sealant. Use it after a wash - and you will get your slick back.
GM has hard clear. I've found great results with microfiber pads.
