HELP urgent! Flex 3401 stop working
Found an electrician that replaced the whole power cord and she's alive back in business! :xyxthumbs:
A simple enough solution to get you back up and running..:props:
Did you replace the same length cord or use a longer one?
Got the picture for you all, hope it helps others in need:
If you can't tell, the SMALL white wire and the black wire go into the same hole at the top of the trigger switch.
Yes thats it! 2 wires under the top screw and one under the other, only that my wires are blue and brown for some reason, blue is neutral.
I put a 4 meters cord in it, should go longer but Ive got a 6 meters extension so 10 meters is all good.
Happy Xmas everybody!
