HELP! Used scotch gard oxy to remove pizza stain now looks worse
No, follow the directions on the label: you spray, then blot, spray some more, blot more. Basically spray and blot until the stain is gone as best you can get it. It can take quite a lot of spraying, but it dries fast.
If it doesn't work, you can use some detergent later if you like. You are going to need something rated for fabric that will remove grease. You might give some Shout or other laundry spot remover a try as well, though they can foam alot and take a while to rinse.
you're not drying good enough after cleaner or it can be residue.The woo lite idea maybe good just neutralize with a little water . the tide pen works great ,I bought a 3000 dollar table with micro on the seats ,my daughter sat on micro with neosporin on her leg ,and the oil was deep in to the fabric.I was on the fence about throwing out chair.I know that seat isn't micro ,don't doubt that little pen I tried everything even extraction the pen saved the chair after 8 applications.
OP--what's your location? Perhaps one of us can save you from needing to rent something.
