RTSVET said:I have a Electron Blue corvette that has soom swirl mark and scratchs in it and was wanting to know what would work the best with the PC 7424 and what pad to use along with the PC.
Thanks RTSVET
killrwheels@autogeek said:I like the Tigershark front on your Electron Blue C5.
First, please realize that Corvette clear-coat is very hard to work on. It is a very hard (not soft) clear. I have found best results with Menzerna IP/FP or Poorboys 2.5/1.0 SSR. I also really like the Optimum Hyper Compound and Optimum polish. Hopefully you will see from above, you will need to use a course polish (more abrasive) and a final polish for best results,
Patience will be the key ... slow and steady. As for pads start with white and move to orange if necessary with heavy polish. Move to grey finishing polish with the final polish. Sometimes you will need to use all three pads in varying degrees.
RTSVET said:Thanks for the compelment on my TS front.
Do you carry all of the product above that you are talking about?
I am just about to place a order for the item #hk-7424 kit can i call you direct to place a order?
RTSVET
aceshigh73 said:RTS....
That might be the nicest vette I've ever seen... I absolutely love the color on that car!
(oops.. after Killr's I mean)![]()
RTSVET said:Scott,
Thanks alot i will give Jason a call tomorrow to place my order.
