^ Those look more like sanding marks. If you did just go to 1500, you could just go straight to 3000. I always sand somewhat aggressive with headlights when I am at the 3000 stage. I then Ease of the pressure towards the end. I imagine like I am drawing and shading and just make sure there is a good amount of lubricity.
The Porter Cable should be able to remove 3000 sanding marks, but you do have to apply a good amount of pressure and make sure the pad is still spinning. Always check heat build up to just to be safe. You can burn headlights.
Also what size pad and backing plate did you use?
^ Those look more like swirls. Which could be from the Porter Cable, pad and M105. After buffing out the sanding marks did you polish them out? With a polishing pad like the LC white pad and something like M205?
Side Note: When I do headlights I like to just buff out the sanding marks with a rotary and then I switch to a DA for the polishing stage. That's just me though since it works faster for me that way.
Also, (It's just me though not sure how others do it) I like using the TufBuf 3" Wool Pad. With either PC or Rotary when I am buffing out sanding marks from headlights, the compounding step.
