Home garage must-haves
Just remember something even more important.... If u want that kinda juice in your garage.... Make sure your house has , at least , 200 amp service. If you buy a house with a 100 amp panel, you gonna be hurting for power
Rasky1,
Holy @#$%! Is that Amazing. Can say I have never seen a heated floor like that before. Very Stupid question though. Is that electric or is heated water ran through tubes?
Thanks Man!
Ray
Rasky, that is incredible! I can't wait to hear how the BendPak SP-7X works out. I have seen a couple of them installed in builds at the garagejournal.com forum and if I was pouring a new garage floor I would go with the in-floor lift. They look so clean.
Thanks! That's actually where I got the idea. ;)
Rasky..what epoxy flooring would u be looking at?
Not sure yet. The concrete still needs to cure for a while and I'm looking at a few different options now. Lots of good recommendations on the Garage Journal forum.
Rasky1,
Thanks Man!
Ray
Heated water. ;)
It's a single zone closed system with 4 loops. Natural gas heater/boiler.
8. Outlets everywhere - Outlets are CHEAP. My builder alloyed a certain number of outlets, and then charged like $40 for each additional. I got a slew of them all around the garage.
Unfortunately you have to be careful here. National Electric code says you can have 9x duplex outlets per 20A circuit. So while you may have 18 outlets, you may only have 2x 20A circuits to the garage. My garage doubles as a a Woodworking area and for example my dust collector alone pulls 20A. My Master Blaster pulls another 18.
I'm not saying that this is the case with yours, but a LOT of builders will cut corners and technically if they do as I described it's still by NEC and local code correct. In my case I pulled a 200A panel to the garage and am running 5x 110V 20a circuits and 2x 30A 240 V circuits for a 6000w overhead industrial heater and a drop for a compressor with room for expansion if needed. All is run with 10ga wire in EMT conduit.
So we're home shopping. We currently have a 1 car garage. I've never had a garage in my life, but one of the few criteria I have for our new home is that it must have a 3 car garage. My truck likely won't fit in it unless we build a new home (not happening) but I do like to tinker, and hope that some day there will be a restoration project in there, probably a 60's F-100 or C-10 (I like my trucks). The 3rd stall will more than likely never see a vehicle, it will probably be set up as a work area.
My must have list currently stands at:
20 amp outlets every 6 feet on the walls
220v outlet for welder/big compressor
Floors epoxy coated (DIY, might look at rocksolid, not the water based garbage)
Lots of shelving/cabinets.
What else would you add to that list? There are some good pics on the other thread, but while I'm sitting here, looking at snow, and my filthy cars, I'd like to know what you car junkies would have in your dream garage.
For the 3 car garage, can you do a separate space, i.e. steel construction?
For the 20 amp outlets, I would bump those to 30 if possible. I know my hot water extractor uses right up to 19 amps. I had the electrician go with 30 amp.
For garage wants: I'd like a 3 garage with a drain and ability to run water inside of it, along with HVAC, fridge, bar, loft with temperpedic bed, entertainment room, bathroom, gas grill outside.... Hmmm. I think I just described my dream house. :xyxthumbs:
Do they still *HAVE* houses with only a 100 amp service entrance?
That'd drive me NUTS! Considering my home theater system alone is on two 20 amp breakers. :)
Our last house was 100 amp box that I upgraded to 150, and it was built in the late 60's.
This house has two panels, one is 150 amp and the other one is 200 amps. :)
Sent from my Trio 7.85 vQ using Tapatalk
Nothing in our area in the last 20 years has been built with a 100 amp service. We built a 20x20 cabin on some property we own several years ago and our only option was 200 amp. I hadn't given much though to more than 20 amps on the outlets. 30 would be a minimal additional cost.
As for the floors, I started by looking at the rustoleum DIY stuff, and have quickly progressed to the more pricey solvent-based epoxies available online. I'll probably rent a diamond grinder. I want to do this right the first time. I don't plan on moving for quite a while.
Thanks again, this has gotten me a bit excited about moving. Rasky, that garage build is amazing.
Epoxy flooring is starting to be all the rage now. Strong as nails and lasts forever. Plus, when you are finished working on your cars, you can polish your floors too.
All I've ever heard were horror stories. I'm so anxious to find an endorsement of one
Unfortunately it's like the rest of the internet. 10 installs, 9 are great and the one that isn't screams so loudly that people think it's all bad. I did mine when I bought the house, cheap Rustoleum epoxy. 17 years later I need to redo it. I'd say I got good service out of it.
We actually looked at stained polished concrete first but it doesn't hold up well in a shop environment with salt and detailing chemicals. Would have looked awesome though. :(
It's all about the prep. If you go on the garage journal forum you find tons of very happy owner who paid to have it done right. I actually asked my concrete guys not to apply the sealer when they poured the floor since I knew I would be applying an Epoxy coating to it.
watching this post! I'll be building a house this year and "detailing station" is a must have. It will be one bay in the 3 car garage.
I would love to use hot/cold water. If I get a water heater in the garage I could tap off it.
Visit your local harbor freight for everything you need.
Ahh but seriously, for me, lighting is a big thing, and so is temperature. So lights, insulation/space heaters/ flooring. You can try the epoxy floring or the rubber mats that are hex shaped or something. I've always wanted those
When I build, I was thinking about putting a couple of drains in floor so I could wash the car in the garage...not just rinseless wash, but a real wash. Has anyone done this?
