PeteT19640
Member
- Dec 17, 2017
- 517
Hi which one is the best?
Thoughts please
Thoughts please
Thanks
One of the cars has been mostly Wrapped and with a Top Coat Ceramic Coating.
Does this make any difference I have seen somewhere don't use a water Blaster high pressure on wrapping as can lift if not careful.
I'm looking for a touchless clean.
ThanksYes a PW may catch an edge of your wrap and can lift it. No such thing as a touchless cleaning. I chased that dragon for a while and it is not a possibility.
No such thing as touchless clean unless all you have on the car is dust. There needs to be contact to clean properly and that’s why most of the times I don’t foam at all, it’s a waste of soap unless the car is so dirty touching it is a big risk.
Thanks
Is that through repetitively using a Pressure washer?
Depends on what you are after. A foam cannon will give you more foam but requires a pressure washer set up. A foam gun is as simple as hooking it up to your garden hose. It won't compare anywhere close when it comes to foaming but the foam produced is there for lubrication.
Thanks
How do you wash?
